Ignition Coil enhancer.
GT20v said:
hehhe my review:
Install at GRA event in S.Alam.nice chap.check everything.Voltage at coil is 14.00Volt..hehehhe thats quite high!! no wonder my car so power(heheh bluff only)
BUt when plug in Volt-Booster(heheh name given by me)Wahlah...volt jump to 18.5volt!!!! even Ivan was shocked..while me?? scared like hell,scared coil burn..hehehe but thats not the case here*..
so on the way to S.alam(sec 27).feel car no power....really struggle.im beginning to feel i make a mistake..but i said nvrmind maybe my ecu need retune....so have to bear with slow car till i come back at home around 5++pm....then i started to rewire everything ngam2(ill solder everything with heatshrink)
reset my ecu.and start the engine....slowly and drive around to let ecu tune.while varying my tps and engine rev....
B4 that we did a comparison....sadly i cant get the spark i post in early rply..hehehhe no one fault,that pic come from coil-over plug ignition.of coz damn good even with oem coil.
but there is 1 thing very2 interesting.without Volt-booster eventhough my spark is purple colour..there's a hint of orange spark occur.this show that even my 14v also not enuff to bring a pure purple spark.When we(i test with chinozie) plug in volt-booster in..wah....its PURE purple no more orange spark.Go n google what is tempreture of purple spark.
cant provide picture as the quality of my hp camera sucks big time!!heheheh
later that night,after some more warmup...i go for a high speed test...
from 0 till 160-170
My vote...Damn good.engine sound diff.as Ivan said Garang.but as my word..spark is hotter and burning better in combustion chamber thus the sound diff.Power??? no need to say.Just go and buy it.:X-:
*CDI=capacitor discharge ignition is another type of ignition(go google if u wanna know more).It store electric in capacitor and give it to COIL when its time.Coil take it and step up the voltage.
Very simple right?? And no coil fried when using CDI.hehehhe last time(check above) im afraid that 18v from Volt-booster will fry my coil..ok??..guess how many volt CDI will give to COIL as a primary voltage before step up the voltage? its 300-350Vhahahhahahah
so you guess la what is a 16v or 18v in my case.heeh got any 20-24v volt-booster??
Sekian.terima kasih
woho bro, i was abit scared when u say no power and tat u did a mistake at the begining :P btw, will discuss with my friend bat the name too, hehe.....
nice nice review...thx man, nice 2 hav a good review from some 1 who is technical.
300-350v, so basically save for my range i guest, think of it like tis, 300-350v in 0.1-0.2 seconds rite? how many times it will charge 300-350v to the coil from 1st - 5th gear?
ocphangaz, good info from u bro, will look up the operating range.
leftfoot, yes bro, can b use with volt stabilizer, using a home made unit with my demo unit, but mine no effect.. :P.
ok then basically i got 4 for the 2nd batch, will call up my friend tomolo
so here's the list
chinozie
leftfoot
howiechoo
kenneth, my friend
but guys, need ur patient again :( let me finish the 1st 4 k?
Yong_5290, hey bro....u change car rite, u got pm :)
juz a reminder
wire cutting is needed
direct ignition system need to b tested
Make sure you reset your ecu if your car is with OBD1 or OBD2 ecu.
simple say..if your car got o2 sensor.then reset the ecu.
disconnect ur neg- on ur battery for 10min.
Xstorm,
Dun worry about cutting wires. When I install VSD, they cut wires to all my four cables. The wires are still there if you still need it. When they remove the VSD, the wires were just loop back.
VSD gave instant power. Gain 1 to 2 secs from 0 1o 100. Too bad it lasted about 2 days. Diden even have change to test top end.
I do believe increasing the coil voltage from 12V to 16V will give extra performance. The only thing is how reliable is it. For this price, worth every penny to try.
See you next week. I will be back this Sunday. Can you PM me your phone no.? I will call you. Thanks.
Bro Xstorm, reserve 1 for me also... Hope i'll get into ur 2nd batch...
my friend will get the higher amp component today, hopefully i can update all of u guys tomolo :)
cyfer, duno mine up to the task or not.... cyfer and hitz, u both got pm :)
higher amp version fail, he saids better use 2 of this rather then building a higher version bcos cost is very high, in the end it will b price up to rm160 each....:(
ill install in a mivec later, c how things go,
bro cyfer, u got pm
bro cyfer, u got pm
very interested bro... can use for honda single cam? wat is the price now?
when the stock coming back... thx..
xtorm diu ler ler!!!!!!!!! mauahahahhahahaaa...
bump bump...
bro, can it be installed on a iswara 12v using stock distributor? PM me the details n price..
thank you.. ^_^
chinoaie n fstrader....thx for the bump
fred......comelor, i wait for u :P
install on a mivec, giving weird reading on the rpm....engine reving ok, but the rpm meter whacko!!! reach 5krpm it will drop. im guessing 4g93, 91 and tose with the same ignition system will hav tis problem....:( mayb waja too....three wiring to the coil.
install in a honda zc engine, giving 17v to the coil.....but he says engine light is on, everything runing ok. i notice there is lots of wiring goin into the coil, msyb there is sensor in it? arrghhh.....getting more complicated.....
toyota 20v runing pretty good now...
im runing external coil, tose 2 wire type, good also.
basically waiting for rply from the mivec and zc engine owner.....hopefully everything ok.
cos my friend is abit busy tis week, he will b ordering the stuff on monday, sorry abt the delay :( cos he dun hav so much capital, he is getting another 5 unit 1st.
everything should b done by friday, saturday and sunday meetup ok?
sounds like a good product, let me know once it has been tested with vvti engine. i'm driving vios and interested with it. thanks:shades_smile:
clubbing9ite, the price is now rm115
HKS-GT2835, still trying to get a digi cam....sorry...
testing fail on the honda with zc engine, he is runing auto gear, the gear cant shift from 3rd to 4th! i duno wat the hack is happening, all it does is giving 16v to the coil.....hmmm.....
my friend decided to get on with the higher amp version....will u guys like to wait or u wana get the current version?
i got camera wor...u wan ahh?? then cheap cheap kasi me laaa ehheheheheh :p
haha fred........
well guys juz when to my friend place, he order three sets..
he also order 1 higher amp version
xtorm said:
haha fred........
hi bro the higher amp version better? when the stock will come(higher version)? what is the price? thx
