Look likes hummer but its Toyota Megacruiser..
http://used.car-market.jp/toyota/img/megacruiser.jpg
Check out the spec..
Standard Metric
GENERAL
Name Megacruiser Megacruiser
Model 4100 (AT) 4100 (AT)
Reference KK-BXD20V-RRPEZ KK-BXD20V-RRPEZ
ENGINE
Type 15B-FTE, diesel, turbo-charged and intercooled, 4-valves/cyl 15B-FTE, diesel, turbo-charged and intercooled, 4-valves/cyl
Cylinders 4 cylinders inline 4.104-Liter 4 cylinders inline 4.104-Liter
Bore and Stroke 4.25 x 4.41 (in.) 108 mm x 112 mm
volumetrique ratio 18,4 18,4
Power 150 hp @ 3400 rpm 150 hp @ 3400 rpm
Torque 280 lbs-ft @ 1800 rpm 39,0 kg-m @ 1800 rpm
Transmission 4-speed automatic O/D transmission 4-speed automatic O/D transmission
Ratios of limps speeds
1st 3.018 3.018
2nd 1.548 1.548
3rd 1.000 1.000
4th 0,765 0,765
RG 2,678 2,678
Low range 2,488 2,488
Axle ratio 3,700 3,700
Hub reduction 1,692 1,692
CONNECTIONS TO THE GROUND
Suspension 4 wheel independent, double wishbone 4 wheel independent, double wishbone
FR/RR Steering box gear ratio 21,99/18,72 21,99/18,72
Turning radius 18.4 ft. 5.6 m
Tires 37 x 12,50 R 17,5-8 (run flat) 37 x 12,50 R 17,5-8 (run flat)
Brakes 4 inboard ventilated discs 4 inboard ventilated discs
Transmission Full-time 4x4 Full-time 4x4
différentiels centre differential lock centre differential lock
WEIGHTS AND CAPACITIES
Overall length 200.4 in. 5090 mm
Overall width 85.4 in. 2170 mm
Overall height 81.7 in. 2075 mm
Wheelbase 133.7 in. 3395 mm
Tread width (front/rear) 70.7 in./69.9 in. 1795 mm/1775 mm
Ground Clearance 16.5 in. 420 mm
Curb weight 6395 lbs. 2900 kg
Gross Vehicle Weight Rating - GVWR 8445 lbs. 3830 kg
Payload 1323 lbs. 600 kg
Seats rows 2 2
Seating Capacity 6 6
Maximum Cant 50° 50°
Approach angle 49° 49°
Departure angle 45° 45°
Angle of breakover 33° 33°
Fuel tank 28.5 gals. 108 l
