How to clean up apexi power intake?
ipul_AE111
32
Hello everybody.
Can someone here share about cleaning apexi power intake. I've try to search the thread but fail to do that.
Is it possible to clean with water or liquid or other chemical?
Apexi filters are dry filters, they don't use oil right? If you're like me, you'll use Dynamo to clean the oil and dirt, rinse it thoroughly and let it drip dry (not in the sun!) until it's dry then use.
es2611
951
175
i always use liquid dish washer and tooth brush.
brush from inside out with slow running water and leave it to dry in the sun.
please dont use powder type of soap as it will leave stain later and its freaking hard to get if off unless u got compressor.
Hi all toyotarians
im planning to get myself an open pod k&n air filter for my 4AFE (auto) engine. the problem is, there seems to have an air sensor attached to the original drop in air filter box. So, if i were to remove that air sensor, what will happen? will it affect the engine or more complicated things will happen?
Need advise and help
keong
