Honda Civic EG9 need help !
I pump the red one actually.. I heard the red v power has a higher rating ?
True ah..
I used ron95 at the start when I got my car but the mileage is not as much as when I use VPower RED
er sorry gentleman im about to buy an eg6 fender, now to know can it fit my eg8 / sr4 without to change my signal and light? tq...:adore:
if i not mistaken, no...
2 door fender's signal cavity is shorter than 4 door. not sure about the mounting points tho...
hey peeps , here are the list of stuff i finally did -_-
open pod simota twister
H4 Raybrig Bulb 5000K , H4 and H4H whats the diff ? O_o same socket diff output ah? - anyways i just got a relay to "boost" the input so that the light would be brighter haven't install not sure it works *fingers cross*
NGK Silicone Spark plug cables
Cold air intake positioned already
Basic servicing all done , new plugs are in but not iridium planning to change to IK22..
Got 2 choices now for cosmetic
SiR Front Lip , PU - RM120 - Rock Motorsports
OEM Foglamp by ESUSE made in TW - RM260 ( wiring,switch,bracket,foglamp )
or Normal foglamp but no bracket and switch and put at the same spot ( looks not as nice ;( ) but only RM100 -_-
HELP peeps ! :D
the OEM foglamps...how should i put this...are there for show only?
they light up the front of yr car nicely but when u sit in the car, the light spread is too close to the front that u cant see the illuminated area. i went for a pair of hella FF50s but have to fabricate yr own mounting n need to cut the bumper if u use 4door bumper...the light spray is super...even brighter than my headlamp!
guys i dunno where to get good effective tint
found Cool World S900 tint :) RM350
lookin for a tint below RM500 but effective of course..
gonna get the foglamp later on -_- wonder the original foglamp can fit HID ? any idea?
Guys ,
im deciding between a set of suspensions..
Mugen Showa ( Non Adjustable )
Kayaba SR Special w/ KG/MM Springs..
Thanks.. Do Advice
