HOnda City Vtec
Yong_5290
Klang
my ride is a honda city 07 n now comes to 40000km mileage
the major service at HOnda SC will cost me 800+ so i plan 2 service it at outside local workshop
but of coz the cvt gear oil will be changed at honda sc since no other gearbox oil is suitable
i plan 2 put Eneos 5-30 semi...any1 tested tis oil b4?
and i think my brake pad's life is going 2 end too...any good brake pad 2 intro?
Mate, are you sure you want to service outside? Cause that will void the warranty, your warranty is either 3 years or 100,000km with Honda. I've tested Eneos before and for City it should be fine. In fact Idemitsu which provides the original lubricant to Honda uses the same lubricant as Eneos. For brake pads you shoud use the original pads or metal king. :biggrin:
Regards,
i wanted diff pads bcoz the pads r not grippy enuf 4 me..
yea i know bout the warranty stuff...but sigh...those money saved can be top up a bit the chg some goodies edi...its like...say 100 for OEM brake pad...130 for Mintex brake pad...so juz add 30 and u get better shit...u get wat i mean:burnout:
Hey bro,
There is also a lot aftermarket breakpad available...
Better gripping? Are u on aftermarket rim or Stock/ori rims...
Can try pumatech, bendix, ferodo, this pad should be within rm200 and below...
If u got higher budget, then u can opt for lemburg, project mui & etc...
i'm running 17"..i use b4 bendix in my wira n it really shortens the rotor lifespan
i tot the 40000km is the last free service you can have....
why would you do it outside?:hmmmm:
Y the free service is 40,000 or 2 years whichever comes first but the warranty is for 100,000 for 3 years whichever comes first. However, before the warranty is up, if you service service outside that would void your warranty. More ever, they will be using your service booklet as a record...:driver:
you have come that long so why give it up at this point to get your warranty void?
Bump: you have come that long so why give it up at this point to get your warranty void?
