- Joined
- Jun 10, 2006
- Messages
- 16
- Points
- 1,503
Application: 88-91 Honda Civic with Hybrid B-Series B16 B18 B20 Engine.
Our Honda Civic RRP turbo kit is designed for street use or those weekends at the racetrack. Horsepower gains are usually in the 200hp range and gains for torque. The 88-91 Honda Civic kit can be used with stock injectors for a 7psi-10psi level of boost.
88-91 Honda Civic Turbo Kit consists of the following components:
1. Microtech MT4 Fuel Controller
2. RRP Cast Iron Manifold
3. RRP T3/T04E Hybrid Turbo(eff. to 400hp)
4. RRP Intercooler
5. 35mm External Wastegate(7psi)
6. Blow-Off Valve
7. 2.25" Aluminized Mandrel Bent Piping
8. 2.5" Downpipe
9. Silicone Couplers and Clamps
10. Silicone vacuum line
11. High pressure fuel line
12. Steel braided -3 Oil feed line
13. Oil Return Line
14. Necessary Vacuum Lines
15. Necessary Vacuum Tee's
16. Necessary bolts and fasteners
Enquiry:
Honda Turbo Kit/Tech/Foto
http://rossracing.fotopages.com
4. RRP Intercooler
6. Blow-Off Valve
8. 2.5" Downpipe
13. Oil Return Line
Enquiry:
