Apexi turbo kit for B16/B18 series
race_parts
Brand new Apexi AX53B60-P18 (w/o Intercooler) for B16/B18 engine.
Brand new in full box, includes everything that you need.
No intercooler included in this kit ( original kit doesnt comes with i/c )
Fits : B16A/B16B , B18C etc....
Part number : 705-H004
Turbine : AX53B60 specs, IHI
The Apexi AX turbo kits are designed as a vehicle factory replacement kit. The replacement turbo's are manufactured by IHI, a world renowned manufacturer, under the instruction of Apexi engineering specs. Apexi AX turbines incorporate the unique AIRICK system that utilises a patented material between the compressor housing and compressor blade, improving efficiency by almmost 5-6%. This system allows for near 0 clearance and in turn lowers compressor outlet tempeartures under high load, improving maximum power and most importantly turbine response.
The AX53B60 turbine power output is around 300HP depending upon application. The Apexi AX kit comes with an internal wastegate with strong spring actuator that is adjustable as required.
Features:
- Special AIRICK system
- Strong spring actuator
- IHI Ballbearing Turbo
- Stainless Mesh Hoses
For other parts listing please visit www.racepartsonline.blogspot.com
Thanks
