anyone here have a problem with water entering to the car from the back??? i heard alot of satria got this problem...anyone know where to fix it??how much???
oh... bro try pour water at your rear bonnet (upper of your bonnet near the roof part) check if the water can be past through the rubber lining... if rear lamp, check between the lamp with the body, or take out the rear lamp check if any path that could lead water to pass through...
already check it out when i go wash car...seems like the water came in to the car from the plastic cover behind the back right lamp....so how to fix?anyone know how???and my lamp inside got water....
can get it from spare part shop, some d.i.y shop, some car accessory shop also got it...
some silicon can be harden when apply it, some just act like a soft seal only, some sealant like a soft black tar, normally it been use to seal some part for car aircond part, u can get it from car aircond service shop also..
I drive a Stock suspension setup Nissan Sunny. Then around last year, I lowered the car and hell broke loose every since. Shocks kong every 3 months...And eventhough it is better than stocks.. But I am not happy with the suspension setup.
THEN, A close friend of mine (Jeff aka Sunnyboy) upgraded to TiTaNs for his Sunny. And I was offered to drive the car for SS03.
I first test drived the car around his housing area the night before the event. I immediatly felt the difference in Ride...
