help me about wiring cd player
zulth
hello sifu sifu semua ...
aku nak tanya pasal cd player aku ni selalu mati..(macam auto restart) bila aku kuatkan sound dia ...
aku dah try tarik cable +ve terus ke player but still macam tu ...
aku guna CD player sony xplode CDX-R 3300.
mintak bantuan sifu sifu ....
bro... i think there is a rule here saying dat we have to use ENGLISH... so pls post ur msg in english...
for ur CD player... i think the prob is on the player itself... not the wiring... send ur player for checking... mayb need some repairs...
Man first i dont understand all of it cause i am not malaysian but i stay here pretty long so i can speak... But plz post ur msg in english!!
Ok whan its loud i dies of right? try it whan ur car is started! if its still dies means go and do ur + wire.. Make a bigger one... Its not the cd player problem... Its when the cd player got not enough power to power up all the speaker its shuts it self down... Then it goes on again... Change ur + and - wires to the bigger ones and it wont happen again...
It helped me...
i am using Sony Expload too!
Its outo shut down to dont make ur cd player rosak!
it would definitely be the +ve wiring... If the wire is OEM - then i would presume that its too thin. If the player is not ground, it would not work at all.
Just try getting a thicker wire and you will be fine.
simefly, i ndun mean not grounded...i mean the oem ground cable is too thin.
it may not be the +ve wire that cause..i had met some case the ground wire from oem socket is haaving problem..
Write your reply...
