Help got clicking noise when brake pressed
Viosman
Hi to all sifu there,
Is this common sound for toyota vios..?
Recently bought a vios and realised got that "klik" sound when brake is pressed.
Is this normal..? Ist the relay sound..? Or switch sound?
When cruising and press deep brake also can heard thr clicking sound.
Im sure its not relay because when i pressed the brake light pressure, brake light turned on without noise or clicking sound, the clicking sound only can be heard when press the brake harder in.
Anyone experience this..?
Thanks to all sifu sifu ya..
---------- Post added at 12:30 PM ---------- 6 hour anti-bump limit - Previous post was at 12:28 PM ----------
Forgot to stated, the clicking sound under the dashhoard on driver's side aroud the brake paddle area. Thanks..
Maybe just the slack space between the pins and the shaft .... don't worry too much,it's pretty normal =)
might just normal sound of the pins lack of grease or just to be sure check ur break pad thinkness.
The noise came from the brake switch which in white color. When i press down my brake pedal in certain level will hear one click sound. The technician told me is normal bcoz other vios got that too.. But i request him to help adjust the brake switch level and the click sound gone unless its pressed to the max. But for normal usage, that wont make clicking sound bcoz brake not pressed until that level also..
Thanks all sifuu
