[HELP]Exhaust Control Valve
why need to spend so much for ecv?new 1 only cost rm280 only mar calvin.
i even sold 1 ori apex'i evc to a guy in johor a couple of month back.:biggrin:
lizard: sorry...no utube video le...
GT: RM280 for wat size?? electronic or manual?? basically, the price is on the high side is coz of workmanship...n they need to use a few "elbows" which is quite expensive (dat's wat i was told la)
2" and 2 1/2 i'm selling at the same price.manually operated 1.electronic 1 don't last long
if u put near the extractor.the heat will kill the motor.
https://www.zerotohundred.com/forums/attachments/237166.vB
Bump:
AUTO car can install?
can...they even install it on superbike.:biggrin:
Bro GT, yours is ori apexi one? whats the exact position to install this device?
will try n share a pic of euro-r using this ecv.
Look nice man... is it automatically open at designated rpm or manually open? since we will only use it during hi revving, without bullet will have better flow thus more power right?
Just wanna ask, wastegate open when exhaust gas pressure reach certain point, in that case, is it possible to install it before muffler like exhaust control valve did?
yes i also looking for this answer:
For manually closed = always closed, for prevent traffic police heard it.
For Auto open: i heard using piggyback, when detect high pressure or reach high RPM, it will open. I not sure how true, the tunner must be good in this job.
For maunally open = always open, i heard very lag at starting.
So is it true for Auto open? pls advise:adore:
from some internet, they said this is call " Virtual Exhaust System "
sample: http://www.atpturbo.com/root/releases/release091004.htm
i've seen this design before in taiwan magazine.i think this 1 works better.it open the
valve base on rpm/boost.but this technology had been around for many years w/o
success.look at arouse mig r exhaust from sard.they adopt the same principle but
different design.
btw rosebrawn,i don't understand ur question on the first paragraph.:hmmmm:
different design.
IC IC. so this system doesn't work.
---------- Post added at 12:19 AM ---------- Previous post was at 12:17 AM ----------
the first line mean there is a switch, which can switch off the system. so that no matter how hard to try, the exhaust will be always stock.
no bro.i mean the actuator version works better then the manual 1.
by the way, how to choose my side for Control value.
2" or 2 1/2" ???
is it measure the diameter of my piping?
found a good stuff:
http://www.nengun.com/apexi/decs-exhaust-control-valve
it can open 20% to 100% at our select choice.
By the way, which workshop can install those Exhaust Control Value ? I tried find 2 workshop in J.B, there cannot quote me. 1 of them said my car cannot do.
However a friend of mine same car and did in SG, have it. but too expensive.
hi bro,where is d best loc to mount tis ecv?b4 muffler or at mid side?thanks bro
i use apexi ecv on my car, to cut down the bassy sound when i pass through road blocks
going to my car to snap some photo after bath :D
noob question...when closed how much gap is left to let the exhaust air flow through????
