thanks for the info pomen...i'll be extremely pleased if i get euro ride quality with lotus handling...if the damping was same... change into softer springs means less absorber work to do...the absorber control the spring movement up-down easier because spring soft so it doesnt fight back the absorber too much......
so if now damping set to hard level...change into softer spring means u can change damper setting into softer setting as well...
changing into softer spring will makes your ride like euro/proton lotus handling....soft spring+high damping suspension.... slightly harsh on really2 uneven surface but very nice to drive... :proud:
not sure what kinda abs i have but im using hwl hlsh body shift...from their website, its twin tube gas filled...didnt mention progressive or not...i've heard of progressive springs but not progressive abs tho...That is exactly what I would do.
Overly hard springs will affect ride comfort. That's a given. And stiffening the abs would stiffen the ride obviously, the thing you need to find out is what type of abs you are using. My previous Hyperflex II H/L/S/H was progressive, anything below 10 clicks was really bad in absorbing bumps on the road. 11 clicks was just nice (for me la) and it was a good compromise between soft and hard road handling (front absorbers). For my rear I put it to 8 clicks to match the front. It handled road bumps quite decently and wasn't too "magic carpet-ish" when going straight. But if I loaded with 2/3 adults at the rear I would stiffen it up to 11 or 12 clicks since it would sink. Obviously it made it bumpier but at least I wouldn't scrape speed bumps or sink too much.
my biggest dilemma now is that i've got mixed feedback...there are basically 2 shops in penang who are well known for selling aftermarket exhaust + suspension systems...i'm a former customer of both...one says my suggestion to swap to 5k 3k springs will work...the other said my abs will die very fast as the softer springs are not a proper match for the abs...and the warranty also will void...i've asked quite a few ppl abt changing to softer springs...some say ok, some say abs will kong...so i oso pening... :hmmmm:
