ecu prob
anuar_fadzli
kl
can or not svt a/t ecu swap with m/t ecu. my still with a/t. and how much for that.(a/t svt20v ecu)
bro anuar
i got 1 manual svt ecu for sales.if u really interested u can call me.
012-2522789
price selling rm300 nett
can,t swap it.. coz connector terminal to ecu not same? a/t have double layer inside m/t 1 layer. need to change ur wiring wif manual gear box...y wif ur ecu.... nice price 4 ur ecu bro....
I think SVT's auto & manual ECU can be swapped coz I've seen a case, a guys bought a SEG with manual SVT from a used car dealer & complaint that the car has no power / very sluggish. So he sent to my mech & he found out that the car was fitted with a auto ECU. He swapped the ECU & everything was fine later.
that what i know sure cant. coz for svt L plug have 12 pin, M = 16pin N = 26 pin. for auto M=16 N=26 O=22. also every pin not same. 1 have manual on this. wiring totaly diff. when u convert auto to manual just bypass some wire n then ur ecu know ur car is manual. sory if im wrong. from this u can do extenal light for vvt. if vvt activate ur light come on.....
I'm no expert but when my mech dealt with that car, I saw it with my own eyes & it was plug & play only wor.:dontknow:
He just unplugged the AT ECU & then plugged in the M/T ECU. So I assume that it's interchangable lor.
Yup, AT and MT ECU should be interchangeable. I've even seen a BT tested using both AT and MT ECU.
Allow me to make things clear:
For BT:
M/T can run with both ECU (similar connector, just plug and play)
For SVT:
M/T can run with A/T ECU + A/T wiring
Power wise no sure.
ECU Doctor have spoken...
How are Sifoo...long time never see you...since the last TTT...
OK, I've just double confirmed with my mech regarding the SVT. That SEG I mentioned originally had an A/T SVT, then someone probably changed the gearbox to manual. That's why when it came to the workshop, it had a manual gearbox but an A/T ECU on it. Or.... maybe some smart ass mech changed the wrong ECU when its original malfunctioned.
However, to what I know is; the ECUs are interchangable (plug & play coz sockets are the same) & both will start & run lor. Efficiency wise, no idea.
yes. indeed my 6speed right now is with an auto ECU. crappy..
see this
http://www.club4ag.com/faq%20and%20tech_pages/ECU%20Japan%204age_20v_Black.htm
Replies
55
Views
3K
sincere1
S
