E-manage ULTIMATE on 4G92P
milo87
hello all.. sorry im newbie and just entered to world of modification....
I have a few question to ask regarding E-manage Ultimate because ill use it later...
1) What the dual map function mean? someone tell me it got switching mode.. 1 tune for street other tuned for race...
2) Izzit worth for my engine?
3) What other features or function?? (explain in simple because i dont know the term2 of engine yet..ehehe)
my mod on my engine: 82mm MIVEC piston + HICAm 286 + BALancing engine + PNP + skimmed head + rebore block + rebore intake manifold + Mivec TB + 4-2-1 powerzone extractor + 2' piping + 210cc injector + FR
mivec piston is 81mm leh, i think u means 82mm high compression piston. dual map is for turbo. coz u can change boost low or high den use diff map for diff boost. use blue more den enuf for a NA.
i buy oversize 82mm mivec piston.. ehehe actually already take e-manage ultimate.. just wait time for installation + tuning... ehehe (thanks for da info bro allance)
if u like DIY style .... buy a Innovate LC-1 WB kit, connect to ur EMU..... u can set ur target A/F map.
Wow....bro, your 4G92P outputting how many WHP prior to your Emanage?
Curious to know
yeah that dual mean....
E-manage Ultimate suit your mod...
oic... thanks bro... i hope itcan give output that can satisfied me.. ehehe neway... already buy e-manage ultimate but dont install yet..ehehe still on run-in period yet...
Curious to know
ehehe... still dont dyno yet.. eheheh not mistaken u also running on 4g92p rite? ehehe... teach me bro...
~Sorry... i donno i post it... and it produce more than 1 post... sorry
Yup me running 92P too....
My mods more on street:
Perdana TB + ported intake, Hot Bits 4-2-1 + 2" piping mendrel bend to Sflow muffler
LCP, 268 cams, PNP + balancing, high comp pistons, K&N drop in filter, Quadcore 10mm cables + Denso Iridium
Still maintain 1600cc with stock ECU. Converted from auto to manual. Last dyno was 115WHP with 138Nm of torque after run in period prior to advanced timing.
oic... now my TB still using standard one... last time already want to put mivec TB...BUT have to cut it out because want to take e-manage ultimate.... i also done ported intake till max as well as pnp till max also...
im running on pz for 1.8 extractor and 2' piping flow route and sparco straight flow muffler... using elevo air ram + poddie from apexi... cable plug also using quadcore... about plug forget to ask my mech... but not iridium want.. ehehe
Hehehe, will be awaiting your dyno results
I will be doing my ECU and 288 cams too plus ACP, and retweak exhaust in the future
oic... thinking to change mine standard fuel pump to evo3 fuel pump..
evo3 fuel pump should be great to replace your 92p fuel pump =p ... your car is heavily modified 92p!
wow...what a mod bro...cant wait to see ur dyno result...show us....
