bro do u mean adjustable fuel regulator? u have the adapter? simple, at the end of the fuel rail where the oem regulator is, just unscrew that part, make sure u open ur fuel tank cap first, and let the pressure in the fuel rail go down first, after unscrew, screw the adapter and the hose to where u want to mount ur afpr, then disconnect ur return fuel line and connect it to the afpr. done! haha, honestly, i suck in explaining
wanna change my tyre for quite a while d, cause i've been using it for more than 3 years, now my tyres always will come out with some noise, make me worry cause i feel insecure when the sounds come out while driving...
Would anyone be able to advise me if the R33 with RB25DET has a speed limiter 180km/hr built into the ECU. The car is an import from Japan( Max speed on the Speedo is 180km/hr. I notice the car 'holding back' and the...
