De-carbonising engine
andlfloh
23
1,503
Any sifus have experience in decarbonising car engines? Does using bottles of cleansing chemicals work as claimed - whatever the brand?
Any reliable mechanic to do this service in Klang Valley?
If full of carbon, best is to do top overhaul and get it cleaned out.....
Neo_
227
52
528
what car are you driving bro ?
how old your car ?
aHLengChai
380
53
me oweys use d-carbo brand.
really nice product for me.. has been tested on my waja (4x) n kembara dvvt (1x)..
fc much better. engine smoother..
DanzEterna
15,911
3,371
www.primeperdanaclub.com
but im abit sceptical bout this dcarbo.....like vr2turbo mentioned, the best way is to get it top overhauled.
once i tried x1r on my toyota LE, at last the engine was jammed. after that day i banned all engine additives.
andlfloh
23
1,503
Waja 2002. Mileage 130k
---------- Post added at 01:50 PM ---------- 6 hour anti-bump limit - Previous post was at 01:45 PM ----------
Do u judge amount of carbon by the mileage done? 100k km and above needs top overhaul, even with regular oil change plus filters.
Neo_
227
52
528
thats like 11 years ready rite.as our sifu's are suggesting here, i too would say its the best for you to go for a overhaul . better option .
Do you have any problems? If not, I will leave it. To check you can also go for compression test before you open the engine up. If all piston compression are good, no need to do anything...
---------- Post added at 03:53 PM ---------- 6 hour anti-bump limit - Previous post was at 03:50 PM ----------
X-1R lube additive or fuel additive. Got people swear they work...:biggrin:
aHLengChai
380
53
my car waja 2001.. when i put that dcarbo into my engine. milleage was circa 160+-k km..
and my dvvt kembara 105+-k km..
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
Acts like metal conditioner. Should not jam the engine....use before also but did not find any benefit...
IMHO... better use tufoil than x1r...
back to topic... use it once, it felt lighter in response (the old engine, before swapping hafkat engine la)
one of my fren did 'decarbonizing' his engine (wira 1.3), but not dcarbo la since that brand does not exist at the time... then got to an argument with his 'uncle-type' mechanic... then the pomen decide to disassemble my friend engine head FOC... he said, for an engine with 100k++ mileage, the head looked rather clean... but not enough
...then the uncle proceed in giving proper top overhaul just to be sure
100k km is relatively still new. Nowadays with proper OCI, engine can last a long time. I would not open up the engine, unless got problem....
Driveshaft for 1.3/1.5 protons
Hi All,
I'm planning to change my driveshaft, not only that, i wanna change the full set alone.
Ok, i don't know what is that called.
Assuming the driveshaft alone is on the right, in the middle is the steel rod, and on the left is also similar like driveshaft but is not.
The reason why I want to change is that, there is this 'kling kling' sound even when driving on straight road, i suspect is the steel rod or the one inside. There is no 'tak...
