I think la, not necessarily true.... 89661-1A360, 1A470, 1A660, 1A860 (letter A) is for manual transmission. See the sticker stated 4A-G M/T
and for the letter E is for auto transmission, sticker said 4A-G A/T
Eh... can swap ECU ka between SVT and BLT? SVT uses airflow meter (AFM) and BLT uses Manifold Absolute Pressure sensor (MAP sensor). In BLT, the sensor is written with Vacuum Sensor Assy with a small hose. Maybe you can if change with complete throttle body kot? Other sensor I dont know...
Bump: I think la, not necessarily true.... 89661-1A360, 1A470, 1A660, 1A860 (letter A) is for manual transmission. See the sticker stated 4A-G M/T
Bump:
I try to answer your 1st question since I've just experienced it few months back.
1) Yes, but with certain conditions :
Front suspension : whole set of spring, absorber and disc knuckle can swap-in, but please be informed that spring 92 cannot mount into 101/111 absorber. Your swap must in complete set of 101/111 spring & absorber.
Rear suspension : Only complete set of spring & absorber can be swap-in, you need to use back the 92 disc knuckle. Again, spring 92 can't mix with 101/111 absorber.
However, some mechanic say complete set of 101/111 rear disc knuckle also can mount in, but you'll need to get the 101/111 cross-member and its complete set of "suspension rods" to modify it. I did try the modification lately, I bought an 101/111 cross-member together with it's suspension rods, but when I try to exchange it, I found that the 92 cross-member mounting holes different a lot with the 101/111, so in the end I've given up.
Hope this may help clearing your doubt.
But how come TRD came up with same part number for some front suspension? Spring and absorber...
Front Spring
AE111 - 48131-AE911
AE101 - 48131-AE911
AE92 - 48131-AE911
All have same characteristic - 31.4 Newton per milimeter K value
Rear spring
AE111 - 48231-AE011
AE101 - 48231-AE011
AE92 - 48231-AE911 - different from AE101 or AE111
All have same characteristic - 29.4 Newton per milimeter K value
Front Absorber
AE111 - 48511-AE982*, 48520-AE100, 48510-AE110, 48520-AE110
AE101 - 48511-AE982*, 48520-AE100, 48510-AE110, 48520-AE110
AE92 - 48511-AE982*, 48511-SW293**
* Note the first type...... 4 stage adjustable rate, cartridge type, same part number
** this one have cross part number with SW20 (MR2)? Woohooo!!!... can cross install MR2 item on our AE92
Rear absorber
AE111 - 48530-AE000, 48540-AE000, 48530-AE081, 48540-AE081
AE101 - 48530-AE000, 48540-AE000, 48530-AE081, 48540-AE081
AE92 - 48531-AE091 only
Please refer to:-
http://trdparts.jp/english/parts_shock.html
for accurate part number. may be we can cross install with other models too... then our AExxx will never have problems in getting parts anymore.....
![Biggrin :biggrin: :biggrin:](https://zerotohundred.com/forums/styles/default/xenforo/smilies/biggrin.gif)
![Driver :driver: :driver:](https://zerotohundred.com/forums/styles/default/xenforo/smilies/driver.gif)
![Burnout :burnout: :burnout:](http://zerotohundred.com/forums/styles/default/xenforo/smilies/burnout.gif)
