CK4 Coilover
Brunei
Planning to change my car lancer CK4 suspension to aftermarket coilovers... Juz wondering if coilover for evo 4 can fit to my lancer?
any recommended brand of coilovers for lancer?
I guess FRont can fit bt nt rear one cos your ride are w/o 4WD sytem and the mouting are diff as well
Thanks for the info... currently no plan to convert to AWD yet as no budget... Wondering any aftermarket coilovers will fit my lancer? Any suggestion?
Evo 123 can fit, just need to use back your old top mount. As for me yesterday I had to bring the top mount to machine shop to bore the hole since its not big enough for the Tein coilovers. Rear coilovers are a direct fit :)
If you want first hand absorbers then look for CJ4A (Mirage) coilovers. Might need to recheck your spring rates. My dampers are having an issue so its a bit stiff, just tested just now. Evo II spring rates. Never ever drive on gravel or brick roads unless you want to mess up your stomach :) Currently I don't have the Tein adjuster wrench and I need to service the absorbers. Good luck, hope I helped.
BTW : The coilover issue is debated in my thread bro.
