carb 4g13 prob.. Help!!
cik_yat
Miami
last week i fill up my tank full wif projet ron97.. Suddenly after start engine and moving, my car was seem like want to die. Yesterday i chek wif mechanic, he say that my fuel was mix wif water.. So i plan to finish up my fuel and fill up wif new fuel but still da same. So i go home and open my air filter box and rammed my car. From my observation, found that fuel was splash out from 1 of 4 hole (tube) into carb. On that time, engine seem like want to die.. da hole is on da top left.. My car using standard 4g13 engine and carb.. can somebody explain me this problem??
mayb u need to take out and service ur carb...
when fuel mix with water, they create white substance.... which might get stuck in ur carb....
I already service last week.. but stil have da effect summore.. in 1st gear need to budget press pedal until reach 30-40km/h.. after that can press pedal more over.. if not, car wil stop and engine like want to die... look like overflow simptom.. how to do??
i guess its fuel supply problem... is ur fuel filter clogged??.. if not, check the fuel lines as well...
arghh... da prob is fuel.. projet fuel in my place mix wif contiment... already clean up my fuel tank and change fuel filter twice.. pomen charge me 70bucks include tuning..
glad u solved the problem... yes, some petrol station use dirty tactics to gain more profit.... in the end, create trouble for us only....
Projet give me the worst power. Therefore never go there again !!
