BOT (Bolt On Turbo)
ya la bro agreed with you...i think the rim already bengkok sikit......but if i wanna demand to change everything to new one afraid that the guy will sabotaj my car.....then what to do......huhuhuh ...
last week tune at sunway saw 1 waja with original engine but got turbo inside........but the hose for intercooler and other hose also change already with samco...nicely done ask the show owner he said that waja cahnging his turbo to ballbearing....
then inside the shop got one new vios also doing the turbokit nicely done and the disc is very huge vttr one as i remember......
now my car already finish the bot project now i think last project to change the clutch plate coz slip.......a lot of slip..........but that one wait first...........
With great power comes great responsibilities...
My suggestion is, brakes and suspension first. Then clutch and also technique
bro sifus..want to ask sumtin..i do bot on my mivec rs with tdo5 turbo..is it enough to use injector 390cc?i plan to run 0.8 bar only before change clutch plate. 1 more, i install oil pressure meter but it is not stable when i speed car at 145kmh..i worry the black oil are not enough somewhere inthe block.i use block 4g93.please advise. thanks:hmmmm:
hummmmmmm yala first thing to do is ....
change suspension and brakes..........hummmmmmmmm but i think clutch first.....
after already change then change evrything rubber hose to samco.....
so how do we know if the black oil is enough or not?....me also worried la like this any sifus..?
Bump: hummmmmmm yala first thing to do is ....
haiz...
no difference mar...
just check with the engine oil lever indicator aka Jarum minyak. Just remember to check the engine oil lever form time not time. Just incase if turbo makan minyak.
Bump: haiz...
haiz...
Bump: haiz...
oil lever form time... can u explain.. :adore:
Sorry... typo... From time to time was what I meant. Just need to check engine oil level from time to time.
Makan minyak itam can be caused by following. Normally it happens together with white smoke.
1) Oil bleed from the rocker cover with the air. can be trace by adding an oil catch tank.
2) Oil pressure too high, goes through the journal bearing and masuk turbine. Simple, just get an oil filter for turboline to reduce the pressure.
3) Turbo kong(common case), service the turbo. But, it's more expensive than getting another one from halfcut.
4) Valve seals kong. (also common) get VITON valve seals of top overhaul set from Century Autoparts. Say Speed2Horizon Recommend. Lolz... Hehehe...
5) Piston Rings kong. (Sad case) Get new rings and replace.
6) Piston lebur/crack (Worse case scenerio). Change engine better than fix back.
7) Also, engine leaking somewhere. cannot see. Crank seal/head gasket/rocker cover gasket/plug seals.
Btw. Driving a CAMPRO BOT is like driving a Honda CIVIC B18C BOT. Not in terms of power, but interms of the tendency to damage your engine. Have to know your limit, and dun be too tamak and boost high. U'll eventually damage your crank. It's one common problem with Campro BOT.
Happy boosting and enjoy your Gsssssssssssssszzzzzzzzzzzzzzzzz....
ok now bosting around o.59 thats maximum la right now.....huhuhuhuhuh
Bump: ok now bosting around o.59 thats maximum la right now.....huhuhuhuhuh
aiyo afraid the engine canno tahan....coz wanna used for a long time la bro that car...hehehehhe
Bump: aiyo afraid the engine canno tahan....coz wanna used for a long time la bro that car...hehehehhe
Bro, when dealing with CAMPRO BOT, U worry more about your crank first. Then your pistons. CAMPRO have high tendency to break their crank...
change piston la bro !
can boost 1 bar :) hehe!
Changing pistons is not as simple as saying it.
1) availibility of the piston bore size in the market.
2) Even if the piston size is available, whan about the pin location..? Too high/low is also not suitable. 1mm make whole damn lotsa difference in the compression ratio.
3) Compression ratio of the pistons rated.
4) The compatibility of the pistons reinforcement flap/pin diameter.
Well, customizing pistons are available, but does the price justify the result..? Like i said, at the end of the day, it's the CRANK, not the pistons alone...
BTW, there are more things that meant more than how much your boost figure is... Enjoy. HAppy and safe boosting.
hehehehehe.........anyone know how much to replace the black rubber hose with samco look alike i mean the silicon one.......
Bump: hehehehehe.........anyone know how much to replace the black rubber hose with samco look alike i mean the silicon one.......
hose from where to where..?
thickness..? Diameter..?
hi bro, i got some silicone hose extra, if u interest i selling it for cheaper price la.
brand new bai... Samco and turbosmart brand, but i got size for 2inch and 2.5inch, long as u like kekeke
Bump:
