I just bought a brand new Proton Wira Aeroback SE 1.5 M/T..
I like to find out what is the best way to season a brand new engine.. Any Sifu know?? :)
Warning: This is a very controversial topic !!
I wrote "Break-In Secrets" after successfully applying this method to approximately 300 new engines, all without any problems whatsoever.
Links to this article now appear on hundreds of motorsports discussion forums from all over the world. The reason is that over time, large numbers of people have done a direct comparison between my method and the owner's manual method, and the news of their success is spreading rapidly.
The results are always the same... a dramatic increase in power at all RPMs. In addition, many professional mechanics have disassembled engines that have used this method, to find that the condition of the engine is much better than when the owner's manual break-in method has been used.
The thing that makes this page so controversial is that there have been many other break-in articles written in the past which will contradict what has been written here.
Several factors make the older information on break-in obsolete.
The biggest factor is that engine manufacturers now use a much finer honing pattern in the cylinders than they once did. This in turn changes the break-in requirements, because as you're about to learn, the window of opportunity for achieving an exceptional ring seal is much smaller with newer engines than it was with the older "rough honed" engines.
In addition, there is a lot less heat build up in the cylinders from ring friction
due to the finer honing pattern used in modern engines.
The other factors that have changed are the vastly improved metal casting and machining technologies which are now used. This means that the "wearing in" of the new parts involves significantly less friction and actual wear than it did in the distant past.
What's The Best Way To Break-In A New Engine ??
The Short Answer: Run it Hard !
Why ??
Nowadays, the piston ring seal is really what the break in process is all about. Contrary to popular belief, piston rings don't seal the combustion pressure by spring tension. Ring tension is necessary only to "scrape" the oil to prevent it from entering the combustion chamber.
If you think about it, the ring exerts maybe 5-10 lbs of spring tension against the cylinder wall ...
How can such a small amount of spring tension seal against thousands of PSI (Pounds Per Square Inch) of combustion pressure ?? Of course it can't.
Originally posted by koolspyda@Mar 25 2005, 21:17
very controversial topic!
But it would be interesting to hear our ZTH boys take on this. This topic was disscuss in many forums before (i wont disclose the results yet)
[snapback]841079[/snapback]
Originally posted by fstrader@Mar 26 2005, 12:44
just ram the accelerator kao kao lar...thats wat enigines are made for mar, to last...if not last then better opt for electric hybrid cars lor :D
[snapback]842486[/snapback]
Originally posted by Radical_Putra*+Mar 26 2005, 14:30 --><div class='quotetop'>QUOTE(Radical_Putra* @ Mar 26 2005, 14:30 )</div><div class='quotemain'><!--QuoteBegin-fstrader@Mar 26 2005, 12:44
quite true LOLx my friends wira had a problem with his car.So the machenic took his car with him and rev it all the way up to 6krpm :lol: my friend very sam tung now LOLxOriginally posted by cyclonite@Mar 26 2005, 22:35
If you're buying proton don't bother because those car delivery man would already red line your engine all the way from the manufacturing plant to the showroom. It's true, they just wanna have fun with customer's cars and couldn't care less.
[snapback]843385[/snapback]
quite true LOLx my friends wira had a problem with his car.So the machenic took his car with him and rev it all the way up to 6krpm :lol: my friend very sam tung now LOLxOriginally posted by crazykid+Mar 27 2005, 02:54 --><div class='quotetop'>QUOTE(crazykid @ Mar 27 2005, 02:54 )</div><div class='quotemain'><!--QuoteBegin-cyclonite@Mar 26 2005, 22:35
Similar threads | |
