Before & After ..anti Roll Bar ??
alien, still cant get it ?
well try to think of a see-saw. the fulcrum is the triangle thing in the center rite ? when its in the center both side is balance. but if u move it towards either side the side which the fulcrum is closer to will be harder to lift the other side up. emmm.... izit too complicated ?
or think of a steel bar. when u put ur hands on both ends is easier to bend it compare to if u put ur both hands closer to each other. ...i also blur already..:confused_smile:
cheers bro... It will make your ride feel firmer. but the only problem is that if there less flex, then you would have problem!!
You will start to do Initial D :confused_smile:
There are 2 specs of anti-roll bar for the Putra
Pre-99
23mm front and 13mm rear. This is the same as the Wira/Satria 1.6 and Wira 1.8
99 and Post
18mm front and 13mm rear
5 pages and all I see is hearsay and urband legends. Pity the newbie who would want to know what is an anti-roll bar and how does it work to effect suspension handling.
Go here to understand what is an anti-roll bar. The US folks like to mention the arb as anti-sway bar. They are the same
http://www.turnfast.com/tech_handling/handling_antiroll.shtml
Mike Kojima has an excellent article on how the anti-roll bar affects a FF car's handling and how it is used as part of suspension tuning.
http://www.sentra.net/tech/garage/suspension.php
Read more, talk less..
Putra4767,
If you want a stiffer ride get higher rate springs and likewise a shock with higher rate damping.
Pre-99
99 and Post
hi bro wat is the size ARB for wira 1.3 & 1.5 and Evo 3 ??
im driving a wira 1.5 efi auto
After long consideration, i decided to call kent20 to get the zenden strut bar
After installing it, it made such a big difference
Previously, when i go on bumpy roads, my gf will make noise coz its too bumpy
Now me myself n her are so happy
But i just installed the front strut bar
Havent install the rear lower bar
Will the rear lower bar be important?
Guys is there any formula to calculate how stiff an ARB and Suspension should be in a street car and race car??
guys... need some advice...
the bush for ultra racing ARB.... boleh pakai ka?
guys which 1 ARB to install?? Ultra racing ARB ?? or Eibach ARB?? Ultra racing is abit cheaper!!! but Eibach is well knows in suspension....
Hi all, just wanna go further a bit hehe....... instead of talking bout individual arb lets see whats the best overall setting front and rear and the difference between front arb mount to absorber and those mount to lower arm etc
So lets start with a satria non GTi, if use 23mm absorber mounted front arb to pair with 16 or 19mm rear arb would it be a good set up?:nurse: Million thx!:adore:
The Zenden rear lower bar you are talking about is different from the rear ARBs that these guys are talking about.
xbalance2002,
The Eibach ARB set is selling for quite a reasonable price these days, wanted to get them, but really no budget yet. I went for the Ultra Racing 16mm rear ARB instead, and i'm quite happy with the handling for now. Will get the Eibach set when my bonus comes in :driver:
xbalance2002,
The Eibach ARB set is selling for quite a reasonable price these days, wanted to get them, but really no budget yet. I went for the Ultra Racing 16mm rear ARB instead, and i'm quite happy with the handling for now. Will get the Eibach set when my bonus comes in :driver:[/QUOTE]
what is the price for eibach ARB set rear and front???
If i'm not mistaken, there was one advertisement in Hypertune a few months ago... they listed the price as RM899. Forgot which shop already... :rolleyes:
Some background for Anti roll bar :
Anti-roll Bars
The primary function of anti-roll bars is to reduce body roll by adding to the roll resistance of the springs.
An anti-roll bar, also referred to as a stabilizer or sway bar, is a bar or tube which connects some part of the left and right sides of the suspension system. On independent suspension systems, the connection point is usually the lower control arm.
Most cars have a front anti-roll bar, and most sports cars are going to have both a front and rear bar. After market bars are going to be stiffer than the stock ones.
Roll Resistance
Anti-roll bars are used to reduce body roll during cornering. They add to the roll resistance of the suspension springs for a higher overall roll resistance Because the primary purpose of the spring is to maintain maximum contact with the road surface over imperfections, we must settle for the roll resistance provided, and it is rarely enough. The anti-roll bar adds to the roll resistance without resorting to an overly stiff spring. A properly selected anti-roll bar will reduce body roll in corners for improved cornering traction, but will not increase the harshness of the ride, or reduce the effectiveness of the tire to maintain good road surface contact.
So, how does limiting body roll improve handling? The suspension system geometry (the lengths and connecting points of its parts) of a street car is designed to keep the bottom of the tire parallel with the road for maximum contact patch. At rest, the car's suspension has a particular geometric relationship to the road surface. Body roll changes that relationship, and reduces the suspension's ability to keep the tire parallel to the road.
During body roll, the car body is no longer parallel with the road, and neither is the suspension geometry. Even though the suspension allows the wheel to be somewhat independent from the body, the high cornering forces, and resulting large body roll of a factory car, on the track take the suspension close to its limits where it affects the angle of the wheel.
Large amounts of body roll cause the wheels to tilt away from the corner which lifts the edges of the tire and reduces the contact patch size. While this can be compensated for by having the wheel purposely tilted inward to start (adding negative camber), there is a practical limit to this which is not enough in most cars to compensate entirely for the body roll. The anti-roll bar reduces the amount of body roll, and therefore helps to maintain as much of the contact patch as possible.
As with all good things, more is better only to a point. Because the anti-roll bar connects the left and right sides, this reduces the independence of independent suspension. Too stiff a bar, and you can cause too much loss in the ability of the left or the right wheel to independently respond to road surface imperfections. The purpose of suspension is to maintain maximum tire contact with the road. The purpose of independent suspension is to allow the left and right wheels to each seek that contact separately. The left wheel may need to be going down when the right needs to be going up. If they were tied together as with the old floating rear axles, one or both of the wheels is not achieving maximum contact. In fact, too stiff an anti-roll bar can actually cause an inside wheel to lift completely off the ground during hard cornering.
When cornering, the bar will twist with the outside end being pushed down, and the inside end being lifted (just like the body of the car). On the outside tire, this downward pressure helps increase tire traction. However, on the inside tire, the anti-roll bar is pushing up on the suspension reducing the downward force the spring is trying to place to keep the tire on road. If the anti-roll bar is too stiff, it will overpower the spring, prevent it from extending enough to keep the tire on the road, and the wheel will actually lift off the ground. This is not an optimum situation, but it is common in several racing classes. The cause is not so much poor engineering, but the limitations of the class rules that allow the engineer to compensate for it.
Roll Coupling
The anti-roll bar is also used to tune the roll coupling of the chassis. Roll coupling is the relationship of the roll resistance of the front of the car and the roll resistance of the rear.
The balance of the roll coupling, because of its effect on traction, has influence on whether the car has a tendency to understeer or oversteer. While this can be caused by several factors, the anti-roll bar (especially, an adjustable one), can be used to compensate.
As we mentioned, the anti-roll bar helps increase the mechanical downforce of the outside tire during cornering. This increases the traction of that tire, and that end of the car (front or rear). An increase in traction at that end, may leave the opposite end with too little traction. An imbalance of traction occurs, and one end of the car will lose traction before the other end. If the front tires lose traction before the rear tires, the car will understeer. If the rear tires lose traction before the front tires, the car will oversteer. Changing the anti-roll bar stiffness can adjust this out.
Summary
The anti-roll bar reduces body roll to keep the suspension geometry, and ultimately the tire, parallel with the road. Stiffer bars reduce body roll more, but too stiff a bar can deteriorate independent suspension performance, and ultimately cause an inside tire to lift off the ground during hard cornering.
The anti-roll bar can also be a major tuning element in reducing excessive understeer or oversteer. Used incorrectly it can also cause it.
Like other parts you can buy for the car, the "killer" biggest, stiffest anti-roll bar you can buy is rarely going to be the appropriate choice. Look for someone experienced with your car, and can take into account the shocks and springs already installed in your car.:biggrin:
Try to understand on Summary section and what u want ( application ).
U will know what size of anti roll bar u need.
:beer:
