if u are lazy to mod, then go for b16b. but if u have lots of time and enjoy the process of modding, then go for b16a, use the balance to start ur own mod.
maybe he try to do comparison which one is better.. if majority say b16b oso almost same with b16a the he might getting b16a... n vice versa...
after getting answer then he will start kumpul duit if his current bajet not permitted.
b16a EK RM7-8k..
and to make it same with type r u need to spend on this
b16b cam + vs = RM1.5-1.6k
b16b valve = RM400
b16b intake manifold = 1.5k
b16b lsd = 1.4k
b16b ecu = 0.5k
b16b extractor = 0.4k
b16b head = 1.2k
total different = 7k + 7k = 14k
so better get b16b engine conversion @RM11k
but that one if got intention to mod ur b16a to r...
hehe... btw, avantech got 1 unit engine package for b16b now.. selling at 10.5k only. please pm for details if u interested.
b16a EK RM7-8k..
b16b valve = RM400
b16b lsd = 1.4k
b16b ecu = 0.5k
b16b head = 1.2k
But anyway, hattech has pointed out very clearly the difference of both engine in terms of price and it is definitely way better off to get the B16B if you plan to upgrade to type R later, might as well put it one shot.
Bear in mind that, however, you will get yourself the dashboard, climate control and meter cluster for the price of EK4 halfcut mentioned here between 7~8K while you only get the engine for 10~11K.
its only worth if u got ek4 99 hafkat with 99 spec dashboard with that price... if 7-8k only got ek 96 hafkat better use back ur original dashboard... haha
or maybe get a complete car from singapore... hehe
if getting a b16a, it is not worth to mod into b16b already. its "better value" to get some aftermarket performance part.
how come in kuching here, b18cR is cheaper than b16b? i know one B18CR with 25k milleage going for 10k only. anyone interested? can shipped to kl :P
B16B here is too hard to source in kuching.
EK4 black dashboard definitely much nicer, if Japan one with digital climate control much shiok, got hot air with fully automatic air flow system... shiok gila ni...... kekeke
Well ok..thanks for the replies. I just wanna use this car for 1 or 2 years only. Wat is the different between B16B and B18C, price? How is the maintenance as i staying in PJ and working in Cyber, traveling everyday, will it be so high maintenance? My budget is abt rm 8K half cut + installation. Mine is still 96 specs so i'm planning to face lifts to 99 specs as well. any suggestion? i need this get done as soon as possible as my engine is really kong.
Erm how much will be the EG B16B half cut? same power as EK? need more ans on this, thanks!!
I STRONGLY suggest you sell off your car and get another ready mod with the engine transplant for that kinda time frame. It really doent worth the efforts to do all the exterior mod and engine transplant and I will drive it as it is if I were you.
you can try pm or calling hattech-v for price quotes.
service maintenance are similar to other brand cars regardless of destination and travel distance. keep your service logs.
>My budget is abt rm 8K half cut + installation. Mine is still 96 specs so i'm >planning to face lifts to 99 specs as well. any suggestion? i need this get done >as soon as possible as my engine is really kong.
again, pm hattech-v for engine and bodyparts.
>Erm how much will be the EG B16B half cut? same power as EK? need more ans >on this, thanks
no such thing as EG B16B. maybe it was hybrid in japan. "same power as EK" translate to endless combinations.
b16a EK RM7-8k..
b16b valve = RM400
b16b lsd = 1.4k
b16b ecu = 0.5k
b16b head = 1.2k
B20B better all complete less then 10 k
hahahah....
its a big potential to mod/stroke up but this depend on budget lar..
b20b siok lor..... rise up more then 220 whp......:tongwink:
hahahah....
Less than 10K? Reliable or not one? What to change if budget is less than 10K for B20B setup? I heard a lot need to change one lah.. starting from the rods up to the block oh!
A new era of engine manufacturing in Malaysia was officiated as Perodua and Daihatsu partnered on a RM500 million investment joint-venture. Daihatsu Perodua Engine Manufacturing Sdn Bhd (DPEM) opens their engine manufacturing plant in...
