Auxilliary Input Cable
digitax
Where to getit? How much would a cable cost? Would be connecting this from the headunit to my ipod.. thanks!
as far as i know.... it depends on whether ur HU is ipod compatible, some pioneer HU comes with ipod compatible but u need to get the adapter which i heard is quite expensive. newer higher end model is usually ipod ready. if ur HU is not ipod ready/compatible the only way i know is to connect ipod to preamp
oh, the headunit is equipped with the aux in .. so basically i just need the cable
if jus the aux to RCA input then go to jalan pasar there lo... RM5 for 3 meter if i remember correctly...
depends la what type of lubang or cable the head unit has for the aux in. for alpine have to use the ainet changer input, so need to buy a conversion cable for ainet to rca. other HU if they have rca then easy lah, just have to add phono to rca adaptor cable (thats the cheap one)..
Most head units accept the AUX input through the CD changer input. So you will have to get the cable which plugs into the head unit's CD changer input (usually a DIN head) and the other end can be either RCA or stereo plug.
I got my Alpine AUX in cable for RM80 (ordered from USA). The local distributor here sells it for RM120 (or RM150), somewhere around that price range.
Of course, if the AUX in is RCA/stereo, then super cheap lah.
Another way is to have a stereo-RCA cable, plug ur mp3 player into the stereo end, and the RCA end, plug it into a pre-amp or directly into the amp (but kinda whacky since the iPod doesn't have a customisable EQ).
Write your reply...
