automatic transmission indicator problem
2731
Hi, my Toyota Camry 96 automatic transmission indicator doesn't work. I did check behind the meter, there is no bulbs to change.how can i solve this problem? need to replace whole meter?thanks.
Did you check wiring? Did you check when you shift, is there any electrical current going to the meter
Yes, all P,R,N,D,2,L doesn't work. I did shift from P to L, but it doesn't work, mean no light on that indicator. But others indicator in meter is working well, just that 1doesn't work. At first, i thought is the bulb problem, but there is no bulb to replace. I din check then current yet, bcos i dun hv device to check it.
Thanks
