Apexi I-moni is a little gadget plugs DIRECTLY into your ISO 14230 diagnostic port on OBD2 (1996 and up vehicles). NO MORE SOLDERING ON THE ECU HARNESS! JUST PLUG AND PLAY! INSTALL AND UNINSTALL IN LESS THAN 5 MINUTES
What it does?
It read out the following:
- Engine RPM
- Vehicle Speed (In both KPH or MPH)
- Battery Voltage
- Intake Air Temp (Degree C or F)
- Water Temp (Degree C or F)
Detail Description:
Selling at Rm1000nett
http://img244.imageshack.us/img244/3168/dsc001671ym.jpg
http://img244.imageshack.us/img244/3936/dsc001702te.jpg
http://img244.imageshack.us/img244/6903/dsc001700af.jpg
http://img244.imageshack.us/img244/8454/twincamtech184895962575nd.jpg
What it does?
- Engine RPM
- Battery Voltage
Detail Description:
A'pexi is proud to introduce the new "i" series of electronics. The "i" series allows the user to access and monitor critical data directly from the car's ECU by connecting to an ISO 14230 diagnostic port on OBD 2 (Onboard Diagnostic) vehicles 1996 and up. Installation is as simple as plugging the i-moni directly into the factory diagnostic port. The "i" series of electronics are compatible with almost any car using an ISO 14230 diagnostic port making it usable on a large number of OBD 2 vehicles. - Segment LCD Display for enhanced daylight visibility. - Display Parameters*: Engine RPM, Vehicle Speed, Battery Voltage, Intake Air Temp, Water Temp. - Unit displays in both km/h and MPH for the vehicle speed, as well as Celsius and Fahrenheit for all temp readings. - Unit also has a peak hold function
