Apexi AFC Neo price reduce....
Do u have the ECU diagram For mazda BJ5P, FS-DE Engine? If got, i want to buy the SAFC Neo from you.
i read afc neo diadram,inside no FS-DE diagram,but i can copy SAFC 1/2 diagram to you...is same de
wow~ so you got la!! what the best price u can give me plus flight charges??:_:
wat is ur best price for the safc neo...do u have diagram for gsrt engine....wat the safc neo function?
-Completely new case design
- Compact design
- Incorporates both AFC and VAFC functions in one unit
- 16 point fuel correction
- Color FED display
- User defined button and background colors
- Inverted "anti-glare" screen
Key functions include:
MONITOR MODE-
* RPM
* Throttle
* Battery voltage
* Correction %
* Air flow %
* Pressure
* Karmann
* VTEC
SETTING MODE-
* Air map
* Air map graph
* Throttle point
* Deceleration air
* VTEC control
* VTEC unmatch
ETC MODE-
* Model select
* Mode select
* Car select
* Sensor select
* Analog scale
* Warning set
* Display set
* Sensor check
