another subaru 1.6 ts
15devils
6
yeah guys,wanna lower my TS,its a 2003 "new age" model,wanna know if the wrx tein s tech springs would be able to work on the TS?
15devils
6
so is there no one who knows how i can lower my TS ???
josumi
48
bro,
get d tein spring for 1.6ts. is available in d market. wrx spring doesnt fit.
15devils
6
where bro ?? you have a website where i can get it ??
josumi
48
im not sure which web site. my fren using d absorber. i only know where to get it only
riggy
146
tein s-tech springs for the ts is actually the s-tech for STI. My 2004 ts uses s-tech springs. These are too soft for STI actually but just nice for the TS.
There are no specially made springs for the TS, but they work just nice as the TS is almost 150kg lighter than the STI so the spring rates are just nice for the TS.
i dont know where you can order them from, but i think any tein dealer can help you get the STI S-TECH.
Everything from the WRX GD series should be able to fit. Subaru makes it all interchangeable. You can swop everything -shocks, springs, links, lower arms etc. just make sure if your version is the blobeye ( GD applied C onwards) for the parts to fit. Bugeyes may have slight differences in the mountings for the shocks.
regards
All sifus,
I plan to go with S90 @ 70mm throttle body and aftermarket aluminium intake manifold to match with my Deratech cam.
Meanwhile, is upgrade on air flow meter is necessary?
If needed, what is the air flow code number is good to upgrade?
Also, changing in bigger air flow meter will make the engine run lean ?
Please advise and educate... Thx.:adore:
