Altezza At convert to MT?
motorfreak
Sifu,
is it possible? need to change ECU for this conversion? any advise?
it can be done and our brian just did that .... successfully, i heard ... with the able hand and expertice of trial stuffs especially william san ... hehehe :shades_smile:
to convert from auto to manual , u need to complete front and back of altezza. u need manual ecu, manual ecu harness, gearbox, rear axle, etc... a lot more la... the things that i didn't change is only the engine and ( interior except meter cluster ). the most important thing is the ecu. if u convert without manual ecu, ur car will be more sluggish than normal altezza auto.
yikes! so complicated one ar :mouth_closed: no other choice except to search for ori manaul:sad_smile:
go for 1jz engine conversion. i noe 1 fellow in sungai besi who's expert in 1jz. but bear in mind... after installation all will be packed under the hood and also u will be hard to find after market parts. all have to be custom made. this is the main reason i give up to hav 1jz in my car.
1jz ?????????
cannot lar......... because it too fast already... later we all cannot chase him.......
no no cannot....
* cabut *
hehehhe
martinchan said:
1jz ?????????
no no cannot....
* cabut *
hehehhe
wanna be a bit sarcastic .... can we chase him even now???? .... hehehe
chase the 1 with 1jz? sure can 1... endurance race. hehe.
motorfreak, plz come out and join us tonight. shell ttdi 10pm. we need more altezzarian to determine which logo to use for our club. c u there
even b4 brian converted to manual...hard also to chase him. With his skill and bravery, he managed to whack an EVO7 one of those nitez after T.T Now, don't bother trying at all....kekekekekeke
done it at TRIAL tmn sg. besi . swapping price rm 6k. if you bring along your own halfcut, then might be cheaper. coz i swap my AT with his MT.
you mean converting from AT to MT only cost RM6K? or this RM6k is only for labour? if it include parts...then is veli..veli..reasonable.
motorfreak... wat dream????
the labour includes - swap of rear axle, long shaft, ecu, transmission, full wiring, install clutch, clutch pump, brake pedal, clutch pedal, manual meter, setting f con etc. lots of work.
rinagi,
i thought RM 6K include all the labour and parts, so that onli happen in my dream lar..
labour to do this is around the same everywhere but do not compare with shops in sunway..
