Afternoon sickness
peyuh83
Hi guys,
Good day,
i am a new members here.
i had problem with my tezza...very difficult and sometime cannot start engine on afternoon...the engine can crank but cannot run...battery and plug still in good cond. this problem didnt happen on morning and night...Hope u guys can give advices how to solve this problem...
any particular strange noise when starting the engine?
nothing...everything normal...crank sound also normal..did diagnose at trial before...everything ok with the system...i suspect mechanical part such as fuel pump or maf sensor...when engine get started...idling rpm stable.....maybe u guys had a same problem
did u do anything to your car before the problem occured? if RPM and idling is stable.. maybe its the starter. Just a wild guess.
i'm oso having these start car problem,oso wont happen in the morning,sometimes nite does, but i still can start it,but just need to take around 3-5 seconds
hi tezzarers,
Did u guys wait for the starter lights to turn off before cranking? Eg. Put key in, wait...indicator lights shuts, then start cranking....try that first. hope alls well.:itsme:
tried,but same,lol. for my case,the chance to start nicely is higher when the lights still on!!!
any possible of fuel pump failure?...i suspect fuel pump or regulator didnt work properly...but not sure..need to try n error...
Hi guys,
Good day,
Bro, you can try this..
Disconnect your battery overnight, next day try your luck.. it may work..
This is the cheap way of doing it..
(Disconnecting your battery for long period mean resetting your ecu to default factory setting..)
my buddies say that i m not active. now active, ada kawan say hyper...:banghead:
Bump: i need more horsepower too! :rofl:
i think disconnecting the battery terminals for at least 15 mins or better 20 mins to be safe is good enough to reset the ecu.. just my two cents..
restarting ecu? may not have any effect.
it could be the fuel pump or fuel sensor. are all in good condition?
