About FC3S
melnikor
kl - kb - kl
Hai all RE sifu
i have some question .
1.where can buy FC3S heavy duty clutch? ie Exedy, OS, prefer used one
2. if i run TO4E,external Bosch fuel pump, front mount i/cooler, and standard ecu, what are the safe boost for my car ?
thanks for helping
buy new clutch such as exedy will be better , on used item you dont know what is the history on the previous onwer ,
On 13bt Stock engine using to4e safe boost will be around 0.70bar on stock ecu , even the same boost lever compare to stock turbine , to4e will have more air pressure .
sugguest you have a Aditional injector controller to add in fuel when you boost in to get better a/f to conserved the engine ,
to run the setup safely and to squeeze every drop of hp considering the money you;re gonna spend i'd say please get yaself a standalone ecu. This will allow you to set and save maps and you get to load them anytime depending on whats the battle. ;)
Write your reply...
