4G91 Gang..
i used to had 1-3 gear using proton's 1.3 gb 4th&5th from a GTi....final drive and differential using mivec....was great...but didnt last long...6 months...mayb due to poor workmanship or my recipe not working....u can try if u want...just wanna say it's possible
having some issues here. 92 non mivec with 93 head. currently having ecu issues(capasitor leak). lets say i cant fix the current ecu(ecu code : MD178330-couldnt find it on the net),if i change the ecu with another unit but different code. do i have to change the air flow sensor as well?cant remember the air flow sensor code. if im not mistaken its 449.
Mitec-i, ooooo really where u do it...... how it feel......... what do umean workmen shop not goog? by the way what the different final drive and differential using mivec compare gti, I thought gear only 5, ang 5th gear is final drive....... can xplain.
haha...i didnt knw where he send it...machine shop i guess to pump out the gears and put it in...plus tat workshop close shop already...lol...i can try ask around if u really wanna play ratio...some of my frens doin it...so if u wan....i let the pros explain to u...
sure.... sure..... because i'm thinking to put gearbx 1.3 for 1 n 2 at my gti.......
hi guys! its been ages since my last post :P .. btw i just wanna share with you one of the craziest 4g91 setup. picture below
the exhaust setup.. phewwwwwwwwwwwwww :burnout:
yeah. for drag use only. btw that isnt my engine :)
btw the coil that u see in the picture above is msd
joe miragei already read your blog a long time ago...... last time used 4g93 then change to head mivec rite..........
could u tell me about this coil MSD, is it plug n play..... n benefit we used it, if the ignition to big also not good rite...... what the spec of car when we need to used this MSD or it's got other advantage.......
hope u don't mine..... thanks
mitec:
got one workshop can do it. in gombak i'm not mistaken. A.H.S workshop. try search in mudah.my.
thor:
if i'm not mistaken, if u wanna use msd you gotta have management system. so, it is not plug and play :)
btw, i'm not really familiar with msd so i cant tell u much about it. sorry bro. hope anyone here can help to add more info about it?
all otai
recently i just bought satria 4g91 injection manual.after a month i had changed aerospeed triplecore spark cable (coz existing already missfire)+denso iradium spark plug+k&n open pod.now my car seems loss power i.e. no top speed n fuel consumption also bad (rm20 from shah alam to klang bukit raja for 2 days and drive in relax mood).there is always jerk in 3rd gear and sometime in 4th gear.sometime when i turn on aircond,the car semput2,and afetr turn off,back to normal.my fren told me may be due to throttle body but my rpm is ok (less than 1, and above 1 if aircond is on=normal rite...).fyi, my piping is a standard 1.3.wanna change to 1.8 inch but want to resolve that problem 1st.i had changed also fuel filter,airflow sensor b4 coz a pomen advised that.i bought this car for everyday working use n now this problem really made me not cool...plz advise all otai out there tq
if i'm not mistaken almost hit 15+whp on dyno dynamics... on dynojet might be higher :)
Jeo's car damn nice... now got power heart to go with the killer looks ! =) awesome stuff!
aee1717,
Double check everything related to ignition and fueling.
thx alvin. really appreciate your constructive comment on my ride. this thread actually taught me a lot about car modifications since when i used 91 to 93 and now, mivec 93. thx to all sifus here including you, alvin :)
hi..i just bought a car with a 4g91 carb engine..the engine is fine but it make a teppet noise very loud..it wont go off..it will be quiet if i only speed up about 120 km about 3 to 5 minute..then a few days later..it will make noises again...another thing is my car only go about 130-140 kmj still it takes long time and it only have power to third gear..if i change to fourth it just wont up some more..standard car can pass me without a problem..i need help from otai2 4g91..
ram,that's a common problem with most/all 4g9X engines...i have that too...cure,?? top over haul and change the tappets?? and use good oil...
ram,
When you bought ur car, did to take it for an oil change straight away?
joe,
Hahaha... can help sure help ma right? Glad to know i've made an impact on other ppl =) May your mivec take u further into the automotive knowledge. =) hehehe... I almost went for 1.8 mivec also last time... but after thinking thoroughly decided to play evo instead. LoLz.
