!!4g91!! said:
Hej All
Need some opinion from you like advice la hehe..
About adj campulley.. Do you know how to adjust at perfect setting..
Expect in manual tuning like D.I.Y.. Learn from others.. I got info like intake must rotate at clock wise and exhaust at counter clock wise,
and another info must be following the exhaust angle for da open adn close for valve..
Do you know how is funtion???..
Now aday my setting is like motor boat.. boop...boop.. Power wise at low rpm but good on top speed.. Hope got help from all sifus here.. :-))
Make me head ache.. Thanks..
Intake rotate at clockwise means
advance, Exhaust rotate at counter clockwise is
retard...so...what will be the result?
Increase Overlap!!! ---> Good for mid-high end with the expense of low end response, thats the other reason how come you car now like motor boat....too many unburn air fuel mixture escape to exhaust (like got racing cam)...hehehehe...how ur car FC...:shades_smile:
Between, did you adjust you ignition timing while rotate your intake cam? if not...then ur car now more advance compare original setting, if u advance intake cam 3 degree thats means u get the same effect on ignition timing, which is 3 degree advance as well, advance ignition timing is good for pickup but with the expense of low end response, why?
Imagine when your engine is on low speed, piston movement is slow, when you too early ignite, when the Air Fuel Mixture burn
1. The force againts piston (Piston this time still moving up brother, so, result might be, engine knocking, expense engine power cause need more force compress which engine still within compression stroke)
2. Too early ignite also means burning very fast end...so....this time ur engine still in power stroke...do I need say more....lost of power
3. Engine pi ka boom faster....why? For the outcome 1 and 2...Engine working on higher compression (Guys, I referring to dynamic compression ratio, whcih we call DCR), thus higher temp, plus Air Fuel Misture too fast kao tiam, no much leave to cooling down the piston...piston meld....:shocked:
But advance ignition timing is good for mid to high end when we play pickup, if you bring alot barang/human/animal/sambah, and always naik turun bukit...not good....
It is recommend basic ignition 5 degree +-1...but my engine have no problem running on 11 degree advance
Advance Cam Timing also lead to higher dynamic compression ratio...thus...certain rpm you will feel car more responsive
Different engine have different setting on cam even on stock cam pulley, many FUCKER machanic based on Adj Cam Pulley marking adjust for you or ask you opinion BERAPA LU MAU, the correct practice is open rocker cover and use precise tools to measure the cam timing againt crank angle, and of cause dyno tune is the BEST.
Remember, different engine have different setting, dun copy....hahahaha
Just my 2 cents... dun bakar aku.... :shcokedcamo:
