cpmah said:ya oo, I think so, but where do you install your SGTI TB? any recommendation? I am staying in Cheras bt.9. and my ECU is 5660. is your ECU same with mine?
My problem is after install SGTI TB, the engine rpm run at 1.5K and switch on aircon is 2.5K, if change back 4G91 TB, everything normal again.
Hmm, more than a yer oledi.. i also drive damn kaw with it.. hahahah.. it is konged becoz of the jammed clutch bearing eating up the clutch cover diagfram.. if not i think should be able to last for at least 6 month to one yer.. the plate still ok..ayell said:How long u use before it kong arr? Mine already almost a year I think.. I thrashed it everyday.. still gud till now..
ijoe said:he..he..better mivec piston la..lg cun..mine use normal piston je! but high comp la...
Yong_5290 said:so where can get this paraut cutch?
fadlie said:my 91 auto got prob lar....engine ok, still smooth... but gb prob, cant shift to 4th gear.... 80km/h my engine revvin at 3k rpm.....haha...quite high hah....
wat happen ha? is it TCU prob?
I'm not sure any of us has done dyno stock.. i dont even think there is any in this thread with virgin engine.. heheh.. those that have done dyno as i know is Yong5290, Ijoe and CPmahfstrader said:guys in 91 thread, pls tell me... has anyone dyno on a stock 91 injection engine? wats the hp on da wheel and on crank... thanks bro's.
dareMAX said:After installed SGTi TB 1.5K rpm. Did your mechanic fine tune for you? Shouldn't be, coz some member here are using 60mm also no problem.
Or you bought Siemen SGTi TB?
cpmah said:My mechanic tune the scew max oledi and only can lower to 1.5K, do I need to change the ISC & TPS to 4G91 type? play & play really cannot work~
the tuning you refer to the one screw (near the isc) on TB only or other part?
tajulsans said:If wanna change to manual tranny..
Gearbox F5M211 = RM 300 - 500
Gearbox F5M222 = RM 600 - 1000
Flywheel = RM 100
Clutch kit = RM 200 - 400
Clutch master pump = RM 100
Pedals = RM 150
Drive shaft = RM 100
Installation = RM 100
Gear Oil = RM 30
All in all is around 1k++ loh..
tajulsans said:I'm not sure any of us has done dyno stock.. i dont even think there is any in this thread with virgin engine.. heheh.. those that have done dyno as i know is Yong5290, Ijoe and CPmah
wirafly said::emoticon_U: , the problem is came from your TPS's voltage to ECU, if your machanic experience enuf he shud know to slightly adjust the TPS to cheat the ECU, not exchange with your TPS, dun let him do, get another machanic do it, otherwise both ur 91 and 93 TB koyak then u know
cpmah said:so, wirafly~~ any recommended mechanic for this job? I saw your mention a lot about the Ah yong near cheras puspakom there. Can somebody bring me there?
thx.
cpmah
012-3993300
