Originally posted by TE27levin@Dec 17 2004, 10:21
i feel there is different when i convert my 7AGTE from distributor to Dli..
I'm glad that you also like this topic to continue and not take it as a fight. I'm very happy and feel relief you're not up-set or take it too personally. Like this good lah, we can continue talk kok sing song :)
I also wish to take you out more next time you come, go mamak, eat, drive, :)
Well, regarding the feel, I think it is not just the stronger sparks, but also comes from the very different ignition timing.
With ignition timing, the other physical things that would affect it's behaviour is spark plug's GAP. Use 0.8 mm versus 1.1 mm also will change ignition timing.
That's why 20v cannot use 0.8 gap, because their map already very high degrees, closer gap makes faster timing....
That's why GZE ignition map usier to use, cause originally designed for 0.8 mm gap, and coupled with low compression pistion - the maps are very different.
