- Joined
- Jul 5, 2008
- Messages
- 165
- Points
- 1,518
I think this type of engine mounting is the best for your EE90. Coz I'm driving an EE90 too with BT and i'm using this type of mounting. Easiest to modify, less problem and no Q&A session with the Puspakom guys
Most engine, brakes and suspension parts from AE111 can be retrofitted EE90. Some just plug and play (swap without any modification) My AE92 is using AE111 twinpot front brakes, AE111 rear brakes, AE101 suspensions (springs and absorbers), driveshafts, steering rack. Some of the part number are the same from AE90 thru AE111 such as front spring, rear disk pad, etc
But you cannot put AE111 seat into EE90 without modifications because the seat mountings of our AE92 is are different from AE111. You can get a complete AE92 front and rear seat. If you are lucky enough, you can get a complete AE92 GT APEX seat.... But much more expensive than AE111 Good luck with your conversion...
