manual boost controller, need help
chaf
33
1,508
im using it..... tat's a hose connected to ur internal actuator....
tap from there....
speed2horizon
2,798
334
1,683
tap from there....
For stock turbo with actuator.
U cut the hose from the intercooler piping/turbo outlet to the actuator, install the Boost controller there. follow the arrow.
nuarz_87
Jul 11, 2010
15
tanks dude, but i'm using tial external waste gate, it is ok to use original air filter for up boost? help
throw away ur actuator
u use dirct hose to waste gate also can
-better change air filter apexi or hks u can hear diffrent sound :driver:
ur wastegate how many mm 35 or 38
speed2horizon
2,798
334
1,683
Ok, u get the hose that connects the intercooler piping/turbo outlet to the wastegate and have the boost controller connected there.
2 different way.
If the hose is connected to the bottom port of the wastegate, then u do as mentioned on top. U increase the boost by bleeding out air or opening the controller.
If u have the hose teed and connected to both top and bottom port, then u can connect the top port. But there is some changes in the adjustment. U increase the boost by closing the bleed valve until u achieve ur desired boost.
Mrnazmi
510
29
3,028
Drag City
Works Manual Boost Controller ok ka if to play higher boost (up to 1.5 bar)?
Currently using fish bone (tulang ikan), not really accurate, still searching for another manual boost controller that cheaper...:driver:
p/s: If got budget wanna buy Greddy Profec-B II, huhu. But for now manual boost controller is the best option. (no money no higher boosting..:bawling:)
*wanna ask info on tulang-ikan (aquarium oxygen valve)
-the orientation to install which position???? is it sandwiched between wastegate and boos pressure????
or is it install using "T" which leaks boost pressure to atmosphere before going to wastegate??
speed2horizon
2,798
334
1,683
No need T. The tulang ikan valve is already bleeding pressure to the ATM.
Mrnazmi
510
29
3,028
Drag City
From wastegate / actuator got one hole there, put the vacuum hose there and join the tulang ikan in the middle of the vacuum hose, and continue the hose to the intercooler piping (make one hole there near to t.body, after the B.O.V. holes)
Please top up some more if my explanation is not clear..hehe.:driver:
Newbienissan
Banned
Jul 19, 2010
279
17
earth
there is a hose from the exhaust manifold connected to the actuator, T-bridge it, using the 3 valve tulang ikan, keep the valve open by 1.5, and the 3rd one closed. this will give about 0.8 bar boost to ur stock turbo
errr...2different answer....
i guess both way boost still can be adjusted rite???
I just need your opinion....(so please no heart feeling)
Lately...lots of vtec machine beat turbos in the 300m drag sprint.....dunno what type of turbos and vtecs......the cars are mainly satria/putra VS crx/eg/ef 2dr....most of the time honda wins...what happen with turbos?
