actually for more precious feedback, u shld install the arb and rear sturt on different time else u wont know which is the one given u the most effect result
not to promote, even though UR is using my car pics for AE111 fender and 3pt upper front.
yes it's best with to experince them coz a lot of factor contribute to handling ie. tire grip, camber degree etc.
first i've done...3pt front upper + fender + 2pt rear mid (AE110 cannot use the 2pt top)...
then after increase the power abit plus change from GAB to TITAN...add 19mm rear ARB...
then after convert to manual and increase spring rate of the TITAN... add CUSCO 2pt lower bar...
overall best coz not to rigid...
at least i don't have to change to TRD ARB set...:proud:
I'm interested to install a 2-point top strut bar at the rear of my AE111 but worried that the seat cannot be fixed properly. Got suggestions to install rear mid (as u mentioned) but will lose boot space pulak.. Anyone got info on this?
From the pic in UR website HERE, it seems like the seat can be fixed back properly, but i just want to be sure..
sorry boss for hijacking ur thread a bit..heheh
thanks guys!
AE110 can use this without the rear seat like going for track, unless you're driving daily without them seat...:hmmmm:
not sure about AE111...
http://www.ultraracing.com.my/vgreenwap/image/model/Toyota/Toyota AE101 rear up.JPG
last year try to install 2point top s.bar at the rear but UR only have ae101, ae111 dont have....
FGT & meg_omen : according to this picture,
if install, cannot close the seat back to normal ya?
i personally dun like the after effect of installing the 2 point mid rear bar. yes u can feel the car handling improve but in the long run u can feel the rear chassis start to give up (maybe placebo effect), cuz it produce weird noise. now removed od and tighten th hole wif bolts. suspect due to improperly align/level the bar right angel to the chassis. i don now
* i try one bar at time so can feel the effect.
ahaw : 2 point mid rear refers to the one that stretches across the boot ? or the one holding the rear suspension?
FGT : contacted a UR person, said can fix back the back seat.. but dunno how la. so will probably meet up on monday/tuesday to "inspection" hehe
from my point of view, material used for every item is important.
exemple:
cusco underbrace - material aluminium i guess (which type not sure)
refer to this cases..after accident i notice the cusco 4 point underbrace was broken. why it broken, i believe, their engineer have calculate which point this thing will broken and not effected the chasis.
just question: other brand izzit they do calculation until that limit..or just copy the idea and do most likely same pattern?..that thing you'll should think before install it. i have compare cusco and local made...the material is diffreant...yes local made looks more hard/tough...yes that meet the purpose...but when accident happen..izzit the item will prevent/reduce ur chasis due to impact during accident....
just my 5cent opinion
