its fits perfectly with almost all 14" rims..
You can get it from half cut shops :) i got mine from another forumer but it's EK brakes which is similar with EG and I would say the brake really perform well :) but make sure you have at least 15" rims because it doesn't really fit well in 14" stock rim :)
Brother, i got the eg brake at chop shop. But the screw hole was different, where did u modify the bracket convert to myvi? mind to share?
Which screw hole??The 4 holes??? And how do you define different?
bro, search at zth marketplace > chassis and wheel...
now they use wira disk to myvi knuckle with special spacer.. very got solution also...
Not the screw to lock the wheel, is the caliper bracket at behind the disc rotor.
i do believe that there are ready made conversion brackets
fyi even u have the brackets..some edges of the EG brake supporting bracket will have to be shaved off
Anyone have a good all-in-one centre to recommend?
