Wastegate Explained.
I think I have to rechange the whole piping.... Now my whole piping all 2"... WTF !! My original TB already 2.7"... BUT THE PIPING SMALLER THAN OEM !!!!!!!!!!
Anyway..thanks guys !! :(
Actually I don't understand wad u trying to say. Hehe...
HEhe..ok...explain clearly here...
-Our throttle body inlet diameter is 2.7"...
But after BOT...my mechanic modify the "whole piping" to 2"... which mean my intercooler piping to throttle body also 2"....
-Stock Air intake (MAF)diameter is 2.5" ... They make whole piping to 2" also.... which mean 2" piping to turbocharger...Feel like will having air pressure problem !!
Hope you understand ! :):biggrin:
Kuchai lama ma..... Is like that ge lor.... Lolz... Keke...
It's won;t cause much pressure problem. Just boost finish faster.. cause insufficient volume to stall more pressurized air..
just back from oversea :biggrin:
okie... I will start my project soon.. !
Thanks Taiko !!
guys....sory to interupt....after reading the whole thread now im planning to put a wastegate.... what do i need to modified?
now using standart part....standart manifold....standart turbine with actuator....and a noob boost(below 0.5)....lol... :banghead:
plssss advice needed for a noob like me.... :adore::adore::adore::adore:
Dun look down on the boost number bro... It doesn;t determined on how much horse u achieving... Previously, I was using a medium frame MHI turbo boosting at 0.8 bar... Getting around 18+ WHP. Now that I have changed to ******* Turbo. Slightly bigger with different bearing boosting at 0.4 bar. Achieving anytime more powerful than previously. So, boost number is nothing... It all depends on what's inside ur hood.
However, regardless of what engine, car and turbo u are using... There is only 1 thing u need to remember, u are replacing the internal wastegate with and external wastegate which the exhaust and compressed air acts directly on the wastegate without any reaction media like an actuator. U can either remove the internal wastegate flap and plonk in the wastegate there, or u can close the internal wastegate flap completely and install an external wastegate at the turbo manifold.
But there are more details in the process. Easiest is to close the internal wastegate and use an aftermarket tubular manifold aka banana.
What car are you using ??
how many boost you want ??
What turbo are you using ?
engine 4g63 rvr
td04 turbine
boost now below 0.5....trying to get about 0.8 or 0.7 boost....0.5 consider ok for me.... im not kaki gajah one....does stock actuator tahan if boost 0.8?
ty bro speed for enlighten me.... :proud::proud::proud:
using stock manifold also can put external wastegate ka? huuu....
noob nihh....:itsme:
engine 4g63 rvr
td04 turbine
Just effort of lifting hands. For MHI turbo using std manifold without altering the manifold. Here is how u do it...
Anything u don't understand, drop me a PM
bro speed it something like this kan...
hmmm just curios....this kind of pipe is custome made or can get at shop? :confused:
Yes, the picture you posted is for no sound version. If you wnt the wastegate sound, The wastegate outlet have to release to the environment... Cannot vent in...
http://i793.photobucket.com/albums/yy211/pampersdry/DSCF1048.jpg
is that the wategate outlet?....bro mine to ask.... that wategate piping(whatever it called), where can i get one....available at perf shop ka? or kena tempah or custom made? :confused::confused::confused:
That is wastegate inlet bro. but this type also like mine. Not noisy.
Go to Jian Hang Sri g0mbak. Look for Ah Wah. Explain to him wad u want... He can settle for u and gives u the best solution. He did mine quite nicely.
Tell him Kenny Satria S15 turbo recommend.
erkk bro speed.... the shop is near what?? give me some clue pls....not familiar with that area.... how long do he take to put the thing on my car? :adore::adore:
and if i change the actuator does it effect the boost bar?
reply me soon...coz tomorrow i'll go KL....
wow... kenny satria S15 turbo recommend ....
Tell me more anout S15 turbo la.taiko !:biggrin:
it's near batucaves... Let say batu cave is on ur left side, then next u'll see petronas, then sunway batu caves, then bhp petrol station at a corner of a junction. Turn left into the junction. Then first junction onur left, turn in. Go straight till u see s tayar shop on right. Jian hang is just after the tayar shop.
dowan. Told u to belanja me teh Tarik u dowan.. Lolz...
ty bro speed....lai i belanja u tomorrow...hehehehe.....meet up at Jian Hang if i x sesat la....not familiar with that place...but still...must find the shop :trytofly::trytofly::trytofly:
Taiko ~ Speedhorizo ~ :)
Come ! I belanja Teh tarik + Ns lemak :biggrin: I really want to know about T28 turbo ler..
After CNY i will install..HOPE IT WILL FINE !! :wavey:
Oh ya..taiko..you have any picture have wastepipe ?? Any idea ? I wanna make the wastepipe sound ~FEAR ~ Erm...just make the wastepipe face floor ? That's all ??
Or need to modify the wastepipe a bit.. hope can help ya !!
cheers !!:wavey:
cheers !!:wavey:
Wah.... after CNY use CNY Angpao to mod kah..? Lolz... The reputated exhaust shop will be able to do it fo u...
Point down becasue there is no where else to point. Takkan wanna point on the firewall ma...
