I think is not power lost. Actually is not enough fuel for the car to speed more then 180km/hr . This is due to the std stock ECU that control how much fuel to inject . Are you using std stock ecu with HKS sld type II speed limit defender? If you really want to solve this problem then get yourself a Toms ecu. Is very smooth and the air fuel ratio is very well set by the toms tuner in japan
I use to have a toms ecu those days and my speed is 220km/hr at forth gear in tip tronic mode and i didnt switch to D coz i m getting very near to a corner so need to slow down
The best thing using the toms ecu is there is no rev cut in tip tronic mode
3s- ge engine is a high rev engine . Did you watch the movie initial D? If yes , when the AE86 change the engine , it need to rev til ard 11k rpm then only the power comes in rite? same goes to 3s-ge but not till 11k rpm lar hahahahahaha
There is one member here that i knew using toms ecu , maybe you can ask him some opinion
So , my dear friend , consider getting one ? hahahahahaha
Btw for those who experience the speed ard 240km/hr plus minus, will feel a little vibration coming from under carriage.....so drive safe .
cheers
