Altezza's RS200 limit
250km/h ? are u sure? altezza speedo is so overrated... have tried my top speed, the speedo niddle almost 6 o'clock, but my GPS only showing 209km/h.. the GPS has the accuracy of 3 meters.. and yup, before i got my car speedcut remove, i do fell as the gas paddle kicks back at me.. are all fly-by-wire throttle feel the same way ?
Last sunday tested top speed again when i come back from SIC, speed show on my GPS is 241kmh, but the speedo meter turn to 7 o'clock.
But yet i still don't like that i got bully by those turbo, i need a turbo!!!
guys, just check wit all of the taikos here. what is the speed cut of stock tezza? 180 km/h? if mine can hit 200 km/h then only experience power loss, is it the final drive being tune before?
my one is auto. I heard my another friend who drove an Altezza, he said auto's top end is higher than manual because of the 5speed and 6speed gear ratio.
bcoz the final drive different 5 spd auto 4.1 final, 6 spd manual 4.3 ('02 model)
I think is not power lost. Actually is not enough fuel for the car to speed more then 180km/hr . This is due to the std stock ECU that control how much fuel to inject . Are you using std stock ecu with HKS sld type II speed limit defender? If you really want to solve this problem then get yourself a Toms ecu. Is very smooth and the air fuel ratio is very well set by the toms tuner in japan
I use to have a toms ecu those days and my speed is 220km/hr at forth gear in tip tronic mode and i didnt switch to D coz i m getting very near to a corner so need to slow down
The best thing using the toms ecu is there is no rev cut in tip tronic mode
3s- ge engine is a high rev engine . Did you watch the movie initial D? If yes , when the AE86 change the engine , it need to rev til ard 11k rpm then only the power comes in rite? same goes to 3s-ge but not till 11k rpm lar hahahahahaha
There is one member here that i knew using toms ecu , maybe you can ask him some opinion
So , my dear friend , consider getting one ? hahahahahaha
Btw for those who experience the speed ard 240km/hr plus minus, will feel a little vibration coming from under carriage.....so drive safe .
cheers
cheers
thanks mate. mine is all stock. u're clarification justify my driving exp with my current tezza. yea... i can feel the car has power at certain high rpm especially at 5K-7K. hmm... toms ecu. very interesting. let's cross my finger and hope i get the bonus soon. then perhaps can consider it. haha. any idea on the price range?
Dear Jasonchee98,
That time i bought mine was around 4k++ and is a second hand , New one will be around 7k ++ and when you buy new one you need to surrender your stock ecu to Toms in japan . Thats the terms and conditions by toms in japan
Early this year i bought new mines ecu and i need to surrender my stock ecu hahahahaha
ECU are not cheap my dear friend so you better survey properly first before you purchase , With that kind of money maybe you would like upgrade other area of the car first like suspension , lsd , final drive or those wear and tear parts until the car is in a perfect condition then only go for the ecu
Just my suggestion
cheers
share my experience.
my meter shows 180km\hr but Garmin GPS show 175km/hr.
The GPS only shows 180km\hr if go beyond 180km/hr mark on the meter .
Confirmed at 180km/hr on Garmin the speed cut come in.
So which is correct Garmin or Altezza Meter?. Sounds like Garmin is correct but
does altezza really cut at 180km/hr. No buffer meh... maybe 185-190km/hr
GPS devices' speed sensor is more accurate (with
lower margin of error/variance) comparing with the car's speed sensors lol...
Dear Jasonchee98,
Just my suggestion
cheers
yea... u have a point there. 4K++ is a bit too much. I guess upgrade the wear n tear first. Thanks for the opinion.
i just hit 180km/h on my GPS on the way back to kl. then press full throttle untill the pedal kick back. :p
yes, it kick back. and im surprise it is true...hahaha
nice.... but not for the cut off...
my experience, not really top speed yet at KL-Putrajaya highway, the meter pointing at 5 o'clock and my GPS showing 199km/h. yes, altezza speed meter is overrated, when it's pointing at 140km/h but actually GPS/actual speed only around 135km/h. Can prove the GPS speed is accurate coz it exactly showing the correct value while i try with camry and myvi.
david got so many cars for diff occasion..
oops.. sensitive location errr... better edit.. lol..
btw, welcome back to KL lor...
actually not altezza only..almost all cars are like that..last time i check my integra db8 meter showing 195kmh,but on my gps was 190kmh..
Ya...I'm having a same experience. Pedal kick back after pointing over 5 o'clock and fully pressed. It surprised me too...!!!
not necessary at top speed only the pedal will kick back.
i've tried tiptronic holding at "2", and rev til red line for a short drag sprint, it kicked back too..
A thread every 60 seconds
