Hi all,
Need to topup my coolant. I'm below min now. Current color is green. What coolant do you use for evoX?
Thanks.
Thanks.
HeheheStep 1 : Remove Engine
All coolants will be flushed by now...
hahaha.. Joking..
Look behind your bumper, where your radiator is... (You need to remove the bumper for easy access)
There is a plastic nut with ears on the left if you are facing the car... Remove that to drain all fluids out..
Don't tighten it too much, it will crack...
Fill it up with fresh coolant... Start the engine.. and top it up..
