Increasing the engine performance...
one1002
Hi there..i'm driving a waja auto and i was wondering if i could increase the engine performance?actually, i'm quite new in car modifications..so,i've turn into this to ask some few questions.i've searched thoroughly in this forum,but i'm still not satisfied..
i'm thinking of converting my auto g/b to mivec lsd 4.6 gearbox..what do u think?
then, if i decide to change my g/b,what should i do to increase the engine performance/limit?(applies for both auto/manual transmission)
1.changing to larger pistons?what does it do actually?
2.Installing performance camshaft?what is the proper degree,more than 272 or below than 272?
3.crank pulley?what does it do?
4.cam pulley?what is the difference between crank pulley?
5.i've heard some people talking about changing the engine head...?rebore the engine head?what is it?please help me understand it..
what other modifications can i do for me to increase the power?em,i prefer to use stock engine..NA..not turbo,or engine transplant at the moment.. =) thx..any help will be appreciated!!:wavey::wavey::wavey:
Dude youre using the 4g18 engine or campro onwards?
No comment on the lsd gearbox, no experience there.
1.Bigger pistons as in bore or what? If bore then you'll have a bigger surface for combustion a.k.a more power. If you mean HIGHER compression then im not sure how to explain haha :biggrin:
2.No idea in cam tuning, anyone care to help?
3.LIGHTENED crank pulley: A CRANK pulley is a PULLEY at the CRANKSHAFT to guide whatever belts that need to be driven, a lighter one just reduces weight and makes it easier to rotate. Like for exapmle imagine ur bicycle carbon fiber wheels instead of metal ones lah :rofl:
4.LIGHTEND cam pulley: A CAMSHAFT pulley is a PULLEY at the CAMSHAFT that has to do with timing if im not mistake?* Aftermarket ones usualyl have markings to either retard or advance the timing. If its lighter than stock, the theory is same as above. It spins easier.
5.Changing the head is the middle part of your engine, the top part is the cam cover where ur cams are kept and where you pour your minyak in when you service your car. Then in the middle is ur head (No not literally your head :biggrin:) where the ports are. There are 2 types of ports. The exhaust and inake port. They both are basically holes where the exhaust gas enter and where the fresh air goes in to get combusted. By swapping the head that means lets say...
A civic b-series engine. You can take the 'head' from a type-r civic and bolt it into your normal b-series engine and get performance!
Why though?
Not all heads are the same. Basically there are some the lubang is bigger, or better shaped, or specially designed like the type-r head. Its meant for more air to go in and out.
If you want to get better performance out of your waja N/A I would recomend the basic upgrades:
1.Intake (K&N, HKS, ApexI up to you. I dont trust the unbranded ones tho)
2.Exhaust system, again this is up to you. I have a 'cap ayam' exhaust system in my car but it does give performance. I would also recomend branded exhaust's if your budjet allows
3.Spark plug cables
4.Better spark plugs? *maybe, again up to you :biggrin:*
5.Some kind of air/fuel tuning device. Apexi SAFC or a E-manage would be a good start...
Hey hope i've helped dude! :D
This will increase the engine cc and the higher the cc the more torque you have
272 degree camshaft is good for daily drive and power
lighten crank pulley will reduce the load engine runs, less load and you gain more power
basically just to adjust the cam shaft, nothing much
Campro and 4G18 can't change cylinder head, usually those using single cam engine and upgrade to twin cam for more power
1. ditto
2. ditto (more power on 288 degree camshaft & not suit for daily drive)
3. ditto
4. ditto
5. ditto
6. Piggyback (SAFC2, NEO, E-Manage)
Happy mod :)
thx all for ur input..once again,what if i change my engine head with a mivec head?i found one costs about 1.5k..will it gives me power increment?i know the mivec will not be engaged as i will need to add the ecu,wiring,harness all that..this will be troublesome..i know i know.. =)
for the cam pulley and crank pulley,lighter means,not stable rite if high speed?i often travel back and forth from KL to penang..what will the rpm be if i'm cruising above 120?
pivot vs raizin grounding cable..and also voltage stabilizer..does this two is necessary?i know it wont increase the HP,but will it make my engine more responsive,stable,and last longer?which is better?pivot or raizin?
owh yea,about the piggyback(safc,neo,e-manage), some people said that there's no point of instaling e-manage if we didnt do major modifications...?is this true,as i know,the price of the emanage is expensive,so i dont want to waste my money if it didnt give an increase in performance...
thx all...these are my questions for now.. =)
---------- Post added at 12:49 PM ---------- Previous post was at 12:44 PM ----------
oo..i'm using 4g18p..not campro..hehehe
Well.... you can't use Mivec Head on 4G18 engine =)
perhaps you can go for oversize pistons, pnp, highcam thats wayyyy more better than mivec :D
Lighter crank pulley doesn't mean not stable, it lighten the weight of your stock cam pulley
so your car respond will be faster since the crank pulley is lighter
RPM cruising depends on your gearbox gear ratio
pivot and raizin is the same thing btw, pivot made raizin voltage stabilizer stuffs
owh..man..hahaha...ok,what kind of pistons am i looking at?what is the size?then..it'll increase my cc,still have to go to jpj?huhu..highcam,as in high performance camshaft?sorry,i'm not really used to all the terms here..:banghead::banghead:
throttle body...what does it do if i change my throttle body to larger TB?can i change my waja TB to other TB and notice some differences in performance?
Happy mod :)
not really la bro, my ride has extreme mods on it and its daily driven =)
-ps-
RPW 316 degree camshaft
---------- Post added at 01:10 PM ---------- Previous post was at 01:08 PM ----------
4G18 stock piston bore 76mm
CC increasing without changing block is legal =) no need to go JPJ
yes highcam/race cam = performance camshaft
owh..so what recommended size do u recommend if u want to change my stock piston?
what about throttle body?
thx bro..
the 4g18 is a torquey engine, but not a high-rev engine, thus the mivec close-gear ratios wont be a good match for ur engine
if im not mistaken, one powerzone guy told me of how this waja did the mivec box swap, and had a slower o-100 time or was it the 400m? hehe ive forgotten
dude, no need to change throttle body yet...ur engine is still stock standard
Id say you get an air filter+exhaust system first. Best 2 basic upgrades any vehicle can get, even lorries :D!
yeah.
revving it above 5Krpm is somewhat pointless? :banghead:
i normally shorthift somewhere after 4Krpm.
Just to add
the higher the duration (degree) the less the driveability of ur car, e.g. for racing cams idle needs to be set higher to prevent stalling, n u will get crappier fuel consumption, but nice top end hehe
other than the spelling :biggrin: , the cam pulley allows u to fine-tune ur cam settings; play around with the powerband, making it come slitely earlier, or later
dont rebore ur engine head la...if ur mech sed that, throw him away :biggrin: mebbe the term u meant was skimming the engine head? the purpose is to increase compression, thus increasing power, while utilising the same amount of fuel/air but side-effects are increased chances of knocking and more heat (but skimming abit is orait la, dun go overboard)
those with the 4g18 can opt to install a twin cam 4g15 head, found in the mitsu lancer CK...NOT 4g91 ok hehe...BUT rare...so prolly expensive...n not worth it hehe
just do up the intake / exhaust system properly first, u can opt for an aftermarket cam (check out powerzone or matspeed) as well...and a lightened cam pulley
i feel that the stock spark plugs and cables (assuming they are in good condition) will be sufficient for now
actually...ill get a manual gearbox 1st la hehe
do state ur budget as well, if cukup...then get mivec or gsr terbalik hehe
Cheers!
Thats what I plan to do with my 4g18 too, but recently i notice the k&n drop-in filter had increased.
btw TS, I'm a 4g18 user too, totally stock and I do travel back and forth from PJ to Penang too. maybe we could meet up one day if we were to upgrade our car performance?
so a 4G15's twincam head will BOLT-ON to the 4G18?
anyone did it dy? the stock intake/exhaust header will bolt on to the head? :smokin:
interesting question dat one
as for everything being bolt on im not sure, but ppl have done it edi la
im guessing the stock intake manifold wont be a match, most prolly gotta take the parts from the dohc 4g15, may be wrong here
solli cant help haha
yea IF the 4G15 head bolts on, then i'm guessing one hafta source 1 pc enjin kosong fer misc parts like complete intake etc.
but the idea IS very appealing :biggrin:
stock 4G15 dohc 16V head & complete intake, 4-2-1 extractors, freer-flowing muffler, a good CAI kit (take a pick at the blinding choices available nowadays), better spark plugs & cables and a piggyback to complement the whole setup.
rm2K budget sounds like enuff dy hehe :biggrin:
it's gonna be like a 4G15, but with bigger bore & longer stroke.
gud idea arr? :biggrin::biggrin:
oooo...really ar?i tot it should be faster if change to mivec g/b as it has shorter ratio..but then,maybe the mech did not do a great job kot..hehehe..maybe he did not install it properly?who knows..but most of people told me that changing to mivec gearbox should giv an increase in performance too..
both i've done it!!:biggrin::biggrin::biggrin:
yeah.
revving the mivec g/b?
yikesss..another penangites!!cool.. =) sure2..
definately an interesting question as i dont have any knowledge about 4g15 head..
sure ka RM2K??What is IS?sorry..newbie here..huhu..btw, what car uses 4G15?guess if i want to change from SOHC to DOHC, 4G15 is my only option?
thx all..i really appreciate evything that u guyz helped me..
bajet for parts oni maa.
after stupid NAP review those 2nd parts i dunno la price increase anot. :biggrin:
Just to add
or from Mitsubishi Colt Ralliart Version-R is a 4G15 DOHC Mivec head
