- Joined
- Apr 29, 2009
- Messages
- 73
- Points
- 1,506
[WTS] Imported Hayden ATF Cooler
Item: Hayden Ultra-Cool Transmission Oil Cooler - Model No. OC-1403
Package includes: Hose, clips, 3/8” push-on fittings for quick and easy installation
Price: MYR370/set. Cash and Carry only. Price quoted excluding installation
My location: Delivery anywhere within Klang Valley area ONLY.
Contact method/details: Further details, please PM me. Thank you.
Item conditions: Brand new and sealed.
- Ultrasonically soldered for reliability
- 100% pressure tested at 300 PSI for quality assurance
- High efficiency tabulators in every tube for maximum heat dissipation
- Suitable for mid-size and full-size cars, pick ups, light towing to 3500lbs (1588kg)
- Gross vehicle weight to 18000lbs (8165kg)
- Suitable for vehicle below 2000cc
- Increase Transmission Gear Box Life
- Reduce temperature by at least 20%
Why do you need an ATF Oil Cooler?
Due to today’s traffic conditions and tropical climate, auto transmissions are running harder and hotter. Vehicles on the road today risks overheating their auto transmissions thus resulting in noisy gear box and rough gear shifting. Cars stuck in bad traffic conditions, in a stop-and-go situation, climbing steep slopes, driving in hot weather, carrying extra passengers and baggage could result in over heating the automatic transmission fluid (ATF).
ATF cools, lubricates and cleans the internal transmission components. When transmission temperatures exceed 93°C, the ability of the ATF to perform is greatly diminished. Subsequently, the lifespan of the fluid, seals and moving parts are significantly reduced. This increases wear rate of the friction and clutch plates, and further increases internal temperatures.
Lower operating temperatures means extended transmission life
Heat is generated from the torque converter. When a car is stationery, ATF inside the torque converter swirls around within it hitting the fan blade creating a lot of heat. Although most automatic cars nowadays has a radiator sharing ATF cooler, however it is sadly insufficient. The ATF is send out to the radiator for cooling but the heat from the water could further increase the temperature of the transmission fluid causing it to loose its lubricity quickly.
If the transmission fluid temperature is not kept cool, ATF will turn to varnish at 116°C. At 127°C seals will harden. Friction plate starts to slip resulting in loss of torque at 146°C. Finally when seals and clutches burn out and carbon forms resulting in transmission failure at 157°C. Hayden Automotive ATF coolers has an advance design and a patent pending high efficiency Turbulator in each tube. Hayden transmission coolers provide up to 60°F additional cooling. For every 20°F drop in temperature it can double oil, seals , bearings and transmission life. Lower operating ATF temperatures will protect your investment and save you on costly repairs or replacement of another transmission.
As the temperature climbs, due to stop start traffic or traffic jams, the radiator alone cannot efficiently cool both water and the transmission fluid risking a probable engine overheating situation. Thus the need for an auxiliary ATF Cooler.
The #1 cause of automatic transmission failures is overheated transmission fluid. Today's cars generate extremely high under-the-hood temperatures. Add to that the heat generated by an automatic transmission, and you'll see why adding an auxiliary transmission oil cooler is a must for guarding against costly transmission repair.
Automatic transmission fluid cools, lubricates and cleans transmission components. A transmission cooler is basically an auxiliary radiator that provides extra cooling for automatic transmission fluid. When transmission temperatures exceed 200° F, transmission fluid is strained to its limit. Overheated fluid won't properly protect transmission seals and moving parts. When oil temperatures exceed 200° F, oil breaks down, causing seals to crack and leaks to occur.
Installing a Hayden transmission oil cooler will help prevent transmission burnout. It's a small investment now that can save you on repair bills later. With each 20 degree drop in operating temperture, your oil and equipment life doubles. By reducing your transmission oil temperture as much as 60 degrees, a Hayden transmission oil cooler can greatly extend the life of your transmission.
Q. Is there any maintenance for this cooler?
A. As this is an air cooled cooler, there is nothing you need to do after installation.
Q. Do I need to top up the ATF after installation?
A. Yes but not critical. You can do this at your next servicing. You will need about 200ml only.
Q. How long is the installation?
A. It will take about 2hrs for cars with bodykit. But steps are taken to shorten time required on every installation.
Q. What does it benefit me after installation?
A. ATF cooler helps to extend your transmission life span by cooling the ATF that has been heated up by the torque converter during stop-start traffic. This would prevent the ATF from turning into varnish, which is acidic, and sticky, which is why you see some ATF is brown in color and smells bad. Also when coming out of a traffic congestion, the car maintains its spirited character and is less likely to give that sluggish response.
Q. If I travel Highway often, do I need an ATF cooler more than others?
A. Others needs an ATF cooler just as much as you do, if not more. Local traffic is just as bad as it is highway or expressway. But the need for an ATF cooler doesn’t comes from high speeds but from traffic congestion, traffic jams and common use of low gears for hill climbs and heavy load carrying (fully loaded). All these causes stress to the ATF as it is the only fluid that transmits torque to the wheel, cools the transmission and lubricates the gears. When heated up, all of these working factors lowers resulting in pre-mature failure of your transmission.
Q. I don’t need an ATF cooler if I change ATF every 10,000 or 20,000 km.
A. First of all, this is a wrong presumption. Second its not economically sound in financial terms. Third its totally senseless and illogical. The car itself comes with an ATF cooler that is cooled by your radiator water. Heat exchange is done and controlled by the temp of your radiator water. But this is only useful in countries with winter, also this type of cooler is cheaper to install and to purchase as its cost significantly lower to produce and does not need any R&D technology. If you don’t need an ATF cooler, then remove the factory installed cooler as well. Its obvious that a cooler is required, but factory does not customize to every countries needs. As it would be labor intensive, inventory intensive for spares and production. Thus the car would cost a lot more in general. Thus a 1 size fits all, which explains why are some other parts are commonly shared amongst other models. Cost effectiveness. Changing ATF at regular intervals only makes u spend more money unnecessarily. If as such you stand to loose out as eventually your transmission will still fail due to pre-mature worn on the gears.
Q. Can I install a larger cooler unit?
A. No! Coolers technology is not like buying a house or a TV, where bigger is better. Your transmission works on pressure, a larger cooler would mean lost of pressure and would result your torque converter to work harder to pump the ATF through the system. The distance of cooler to and back of the transmission, placement, the cooler size, cooling capacity and many other factors had to be taken into consideration and calculation. Don’t be fooled by silly statements of slap on the biggest cooler and I won’t go wrong. There is an application for every size and model produced.
Also, please visit the following link.
- AudioQuest King Cobra Audio Interconnect Cable
I wonder if anyone out here can advise on the...
