so it's 3.8k or 5k..or 8k??
Sorry bro i did not repair the ECU on board problem.I have 3 person have a problem like u.the problem already settle.I send back to aussy and the technician do the repair.what do you say $125 ausy yes..but look what a problem broken.And plus freigh about $120 some cost below RM1000.For me if i have a certificate and Dealership...i have a responsible for HALTECH product.Bro do u repair Haltech if the error comes up as a Cant Communicate with Port
sebastian...u buy e6x straight la.....hehe
Yes no problem.All forumer Pls take note.
With the Sprint 500 ECU due to the size of the unit the injector drivers are limited to a lowest of 8 ohm injectors per injector driver. Any lower and the driver will be over-heated and thermal shut-down will occur. If you are using high impedance injectors (8-18 ohm) you won’t have any problems.
If you have a vehicle with low impedance injectors lower than 8 ohms and you wish to install the Sprint ECU onto I strongly suggest that you fit a resistor block for the injectors like found in most Nissan’s, Mitsubishi’s which will take the load off the ECU.
With checking suitability of the unit check the impedance of the injectors. If the vehicle is a 4 cylinder you will use all 4 injector drivers with one injector driver per injector. With using the Sprint ECU on a 6 or 8 cylinder engine you will pair 2 injectors from one injector driver so just remember that two injectors will draw more current from the one driver.
This Message from Tim Adam Haltech
hi bro got a Platinum Pro Plug-in R32/33 ecu?how much it cost?
Sprint 500 can use well for Daily Street Driving but not very ideal for those monsters modification.E6X doing jobs well even monsters drag machine running with there aircond while traffic jams at Bukit Bintang.
