4g64 2.5 stroker kit by brian crower. pls refer attachment
Bump: 4g64 2.5 stroker kit by brian crower. pls refer attachment![]()
i tot got 3L also?http://www.briancrower.com/makes/mitsubishi/4g63.shtml
BC 4g64 2.6L stroker also got hehe
if really got 3L block everyone put d la..ya. i tot jo satria mau masuk 3.0L main drag..
too bad its just a romour la..:sleep:
in sydney i got galant engine 4 piston 3.0 liter.Many ppl here put twin cam head and run 45psi boost with E85.
Bump: 4G64 block 6 bolt in sydney plenty..brapa banyak mau.RB30 engine lots la bro here.4D Diesel block 3liter already run 60psi with methanol.
where your proof that you've got the 4d3 liter block in au? I've been around quite a while to know better. Unless you have proof that you have run that engine on such boost,i'll consider you just another scam!
I agree with you . hopefully some ppl will not take me too personaly , I only wanted facts...not fantasy...,if the facts are there...please prove it...simple...![]()
R_Rocket
If u want to know the 3L block come to my wshop at subang i can tell u how to get the engine.Personally come and see me.
Where your proof that you've got the 4D3 liter block in AU? I've been around quite a while to know better. Unless you have proof that you have run that engine on such boost,I'll consider you just another scam!
Ok sure,but personally? what about the rest? can I bring with me all the others who are interested for the block?? masqulinB8,kroolada,joe1,r_monsta,vteckiller...and the rest can or not??
---------- Post added at 01:43 AM ---------- Previous post was at 01:28 AM ----------
Pehh mamat ni hot ni!...toni li goh li bai...hehehe...tu la 3rdgear banyak sangat hot topic you bikin.
some question,
1. Can I just put forged connecting rod like scat or eagle but use evo standard piston? My aim 300-400hp only. As I know the weakest link in 7 bolt is the rod. Not enough money to buy forged piston
2. or better, just buy vr4 block, but very difficult to find this day
3. If change to forged short block (conrod & piston) is it compulsory to use ARP head & main stud plus race main & conrod bearings?
TQ in advanced
yes u can do that
u can also opt for cheaper solution, machine the vr4 conrod to fit ur evo crank , cheapest
remeber that scat/eagle uses floating piston pin
yes u can do that
thank jin..
what do you mean floating piston pin? mean I have to modify my standard evo piston to fit eagle/scat conrod? or have to buy the pin separately? do you think this mod can hold 400hp?
do I need ARP head stud & main stud and also acl RACE main&conrod bearing for this mod
thank jin..
pin use back piston can use back u can install them but need to modify piston a bit to put in the piston pin lock.
ARP head stud is gud upgrade and insurance when ur aiming for 400hp . Put in Metal head gasket while ur at it. Race bearing n conrod bearing dun need but a gud upgrade also. Better find OEM original mitsu bearing but gud luck finding them in malaysia hehe.
---------- Post added at 11:42 AM ---------- Previous post was at 11:35 AM ----------
example of fixed piston pin,semi floating and full floating
http://www.tpub.com/content/engine/14037/css/14037_104.htm
yes u can do that
thank jin..
do I need ARP head stud & main stud and also acl RACE main&conrod bearing for this mod[/QUO
