VR4/EVO Stroker Tech
sumthing to share with you guys playing with this stroker motor.. take a look at all the attachment below..i've been keeping this in my personal collection for quite sum time
same laa...i also keep that article...he3:listen:
master pulak, curi spectre kang :P
would agree here, just take the 100mm crank from 4g64 normal one n plonk it into ur block , done
alo jinkl , yesterday really ar u with uncle zainal at millenium. very shy la u he3.:biggrin:
kroolada : where got bro, low profileeeee :P
mell_amir: biasa la , not handsome like you mar
yes it's posibble but you need to make a brass bushing at the small end bcoz the diesel piston pin is bigger than evo/fairlady piston...
So,bro proPIPING,
If the above setup is:
4D68 crank
4D68 con-rod
Fairlady piston
This is considered 2.2L stroker is it?
yeap this is a 2.2 ltr stroker
Bump: yeap this is a 2.2 ltr stroker
in potong kereta in kepong i saw 6bolt 100mm crank today and heaps of 7bolt too...
Bump: in potong kereta in kepong i saw 6bolt 100mm crank today and heaps of 7bolt too...
6bolt 100mm crank?? u mean 4g64 with 6bolt crank??:rolleyes::rolleyes::thefinger:
in sydney i got galant engine 4 piston 3.0 liter.Many ppl here put twin cam head and run 45psi boost with E85.
Bump: 4G64 block 6 bolt in sydney plenty..brapa banyak mau.RB30 engine lots la bro here.4D Diesel block 3liter already run 60psi with methanol.
he3...:rofl:
3L wat block?
use evo head ?sure:idea:
Not imposible la JO.RB30 single cam he put RB26 head.4D 3L block he put evo 6 head la bro no need stroker2 la..mau mari sini la Jo.pegi KING CROSS hehehehe.
opps...sori,i thought you are joking:banghead::confused:
Bump:
Bump:
beli la proping..confirm u champion no1 la..
3L wei..
rb30 pun goyang la...
3.0 babe!
fuh..shock la..
nanti org protest la..say cc too high..
by the way wat block la 3L? mitsu magna is also 2.6L
hm...king cross block ke?
