woooo wajarays.....thats good....running nearly 2 years already........your friend that running 1 bar and above.......sangat berani with stock internals....hehehehe
im right know want to move the next steps but trying to save money right know hehehehe...
next mode....
1.boost controller with trigger button from turbo smart / greedy/apexi - somebody give suggestion please - low boost 0.6 - high boost 0.9
Not a tough job. Can be done even using FICD. Just control the idle valve to restrict the air out. IF required more restriction, then add in some tulang ikan(non profesional way) or connect it into another mannual boost controller.
So, turning on the power to the FICD will bleed out some pressure to up boost. Just make sure ur A/F is tuned for 0.9 bars even if u are boosting at low 0.6 bars, so in any case u NEED to up boost ur engine, the tuning is ready to handle the extra air pressure and flow....
This is same even if u use the more high end boost controller.
2.clutch plate custom 6 kaki
Anything is fine. Just make sure there are damping springs. there are brand(s) without damping springs. Not to mention the brand, but I guess U know which one I am talking about.
I have a customer driving Wira EVO 3 on EVO 2 GB. I sold him an EVO 3 LSD GB. But he insist with his clutch without damping springs. After 80km/h whole engine bay shaking. OK back in 120km/h. After troubleshooting, realize the clutch is giving problem, foreman say it's lucky for not having his GB center shaft worn. Else, GB pon takleh pakai anymore.
Then i sold him a set of EVO 3 clutch set. Now he's driving his EVO 3 LSD GB happily.
EVO also can. but need to mod. The diameter not same i think. Need to add in a sarung like condom and use steel/stainless steel mesh for filter.
4.upgrade braking system - this one which model i can use aaa?
I think EVO's Disc, caliper + knuckle can use. Knuckles are the same.
Ok, cheers. Happy modding and upgrading....
