i think you mean 220 as the length in inches of the spring ........... not the spring rate, which is usually measured in terms of KG/mm
Bump: i think you mean 220 as the length in inches of the spring ........... not the spring rate, which is usually measured in terms of KG/mm
it's in mm bro vagabond not in inches....
1 day how to realise wor , somemore 1st time using Adj.
